WTB: wiring harness for 2000 XJ
altierior
i need the wiring harness that goes from the computer to the coil rail, the tps, etc...
and maybe the computer itself
(can anyone confirm or refute whether a 2001 will also work? this would increase my chances of finding something... )
they should both be the same. I cant think of any electrical differences.
the 98 wouldn't work because yours has a distributor.
The only difference I can think of is since the harness your looking for goes down to the transmission, transfer case, and o2 sensor, make sure the harness you get is for the correct command track or select track that you have. Otherwise you will have to cut and splice the connector for the transfer case, unless you don't mind doing that. One is a two wire, the other a three wire, that's the only difference I know of.
You realize you are posting in the SoCal chapter right? Kind of far from PA.
Ah, nevermind, I see you posted it in EVERY SINGLE chapter's for sale forum. I suppose because you aren't allow to post in the national classifieds?
Tool.
haha grimm sure does tell it like it is :p
:D
