94_2wdcherokee
- Beaumont, Texas
iam wondering if i lift my cherokee like 6 inches. could i buy sway bars for it b/c it is so top heavy? if so where can i purchase them at?? all help appreciated
RCP Phx said:If you did deciced you really needed one ,you could use one from a V8 ZJ.
MJR said:You can also get bigger sway bars for the XJ from www.addco.net .
cherokeekid said:I looked into them , it lists them for XJ 84-01 except limited, after measuring the Addco on our 5.9 and my factory LTD XJ sway bar they appear to be the same diamter.
MJR said:The XJ ones are metric usually. I am sure the Addco ones are larger. They offer a 1 1/8" front I think the biggest stock one on a XJ is like 24mm (under 1").
