HO engine accessory brackets, fan
ehall
These are from my 91. I removed them a couple of years ago when I switched to dual-electric fans and the YJ accessory bracket. They should work for everything 91+ but I can't guarantee they will work with all years
This is the stock upper accessory bracket, with a new clutch fan assembly. The bearing for the fan pulley spins smooth and quiet.
These are the stock alternator brackets, modified to support the larger 136-amp ZJ alternator.
Price for everything is $50 for local pickup, or $75 shipped.
Do you still have it? The fan bearing wobbles in my 94 Jeep.
Here is how mine looks like.
Click to view full size photo.
It looks like mine has two pulleys on it. I have 94 Jeep CHerokee 4.0L
Accessory bracket is actually designed for 91-95 since 96 doesn't have the smooth idler pulley anymore, but it will work on a 96 if you take the pulley off. I have that setup on my 91, old style bracket, no idler pulley installed, and a 96 tensioner and ps pump + 96 sized belt.
