OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Hey have any of you guys replaced your computer? And if so any advice? like did you only stick too the stealership? or did you have any aftermarket succes. i have a 95 XJ that keeps shutting off when i hit bumps. yeah its sort of weird. any ways i have replaced everything at least 3 times or more. the CPS- relays- fuel pump-ignition sitch-all connectors- and so forth. i have sent my computer in twice to be rebuilt. the company acknowledges a problem- but the problem never gets fixed. So i am done with it. WHERE SHOULD I BUY A NEW COMPUTER&HARNESS? SAVE ME BEFORE I GO TO A ZJ. THANKS IN ADVANCE FOR YOUR HELP.
#2
Re: new computer
I doubt the computer is your problem, a rebuilt computer is not even the same one. It would be hard to beleve you got two of them with the same problem.
Do you have a anti-thieft system? |
#3
Re: new computer
I also doubt the computer is the issue, sounds like a loose wire somewhere. Have you started tracing wires at all?
#4
Re: new computer
You know, it could be the computer. My 87's will not de-energize the EGR solenoid. Really. I finally troubleshot it until I tested the correct wire comming right out of the computer. I don't understand it, but it still runs fine. So, I capped the vacume supply to the solenoid and since I had a new cat installed four years ago, I still pass emisions, in MA, with flying colors. Picces me off too since I spent a small chunk for a new EGR. So, just maybe it is.
#5
Re: new computer
go to a junkyard and grab another engine harness. there will be a sticker on your comp w/ a number on it, match that nubmer if you can. if not, just make sure that you get the comp from another 91-95 w/ the same tranny. |
#6
Well its pretty odd guys. i have traced the wires, and did the old shake it till it almost breaks. but of course it wont respond in my driveway, but on the freeway, oh yeah not a problem. it is pretty odd. the first time my computer was rebuilt, when it would stall, it would shut off, but the ignition lights would stay on. like check engine, oil, and tempature, you know the lights you have right before you start your jeep. now when my xj stalls, everything goes dead, no power at all. then like both instances, if i wait about 30 secs the SOB fires right up, no problem. then when i check the codes, it tells me the old 55. HOW CAN THAT POSSIBLY BE.
#7
Re: new computer
There are a few electrical things the computer don't monitor.
If you had a failing ignition switch, that would not cause a code. And explain why everything goes off, a bad relay in the anti-thieft could also cause it. Last edited by langer1; November 14th, 2005 at 05:06. |
#8
Re: new computer
I have seen a bad battery cause what you describe. When it got bumped a couple of plates would short out. This is actually not that uncommon if the battery isn't tied down. Make sure the ground from the head to the firewall is intact. Around here a ECU from pull-n-save runs around $30.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist Loveland, Colorado My teardrop build You're just jealous because the voices don't talk to you. ![]() |
#9
Re: new computer
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
ITS not the TRANNY computer.....what is it? | hangubus | OEM Tech Discussion | 14 | May 27th, 2005 14:00 |
Differences between a 96 computer and a 99 computer | xjj33p3r | OEM Tech Discussion | 6 | March 13th, 2005 21:27 |
Computer reset question | casm | OEM Tech Discussion | 0 | September 5th, 2004 09:42 |
Engine computer - can someone help me please? | jma | OEM Tech Discussion | 11 | November 20th, 2003 10:58 |
Is the computer in my 90'(4.0,AW4,231) tuneable? | goldxj | OEM Tech Discussion | 5 | July 22nd, 2003 07:29 |
