OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Have 1989 Jeep cherokee 4.0L with auto Tranny. The transmission shifts out much too low, I have tried to adjust the TV cable at thottle body but seemed to have no effect. the tranny will shift 15 and 25 mph even under full thottle if not manually shifted what else could be going on here. does tranny get input from tps and what should I look for as in voltages from sensor if it does
#2
The tranny does get the shift point info from the tps. Id suggest adjusting or replacing it
#3
Re: Transmission shifts too early
i had a TPS go bad once and it didnt affect idle or anything, it just made the tranny shift thru all the gears and hit converter lockup before 30 mph.... would only down shift if the pedal was stomped.... sound familiar? good luck
mike |
#4
My tranny did strange things also when tps went out,eventually wouldnt shift out of first.Heres a link about a voltage test for tps.
http://members.tripod.com/BillyXJ/SENSORS1/index.html |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Yet Another AW4 Transmission Problem | Yukon | OEM Tech Discussion | 28 | November 28th, 2010 00:06 |
Transmission Problems | tweedles | OEM Tech Discussion | 3 | February 6th, 2004 17:54 |
need help with automatic transmission problem | lapaul | OEM Tech Discussion | 11 | January 21st, 2004 19:08 |
automatic transmission problem on 90 xj need help and advice | lapaul | Modified Tech Discussion | 2 | December 29th, 2003 08:14 |
whining transmission....i think | jeepster1985 | OEM Tech Discussion | 10 | September 17th, 2003 06:14 |
