Old January 7th, 2009, 21:36
cdnabn49 cdnabn49 is offline
Exclamation power steering pump/pulley help needed
ok, newb here... I have a new power steering pump and pulley... my question's are these:
(1) do I mount the power steering pump before mounting the pulley as the new one does not have any holes? New pulley on left old one on the right with the shaft stuck in it.
(2) is the bolt and nut used to press the pulley onto the power steering shaft? The instructions from the pump are vague at best.
(3)here is the new pump with the pulley shaft forward..
Old January 7th, 2009, 22:06
FordGuy's Avatar
FordGuy FordGuy is offline
Re: power steering pump/pulley help needed
You normally need the holes in the pulley to get the bolts thru. It would be a real bitch to remove the assy without them. I always mount the pulley on the bench.
Old January 7th, 2009, 22:08
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Since the bolts usually go through the holes in the pulley, there is no way for you to bolt the pump up unless the pulley is installed after the pump is bolted into place.
Your other choice is buy a pulley with holes. I have bought a couple of them from Napa.
Yes, the pulley is installed with the provided bolt and washer. Put a little grease or anti-seize on the shaft to make it a little easier to press the pulley on. Make sure the pulley goes on straight or it can get jammed up and damaged.
Old January 7th, 2009, 22:12
FordGuy's Avatar
Plus, China? Run Run Run.
Old January 7th, 2009, 22:14
5-90's Avatar
5-90 5-90 is offline
And buy/rent a power steering pump pully puller (yes, it's a special tool. No, it's not terribly spendy) so you can remove the OEM pully - sounds like you need the holes there (on the RENIX rigs, it's not a problem. The OEM pully looks like the one you went and bought.)
Use Never-seez, and get happy with the stuff! Apply to the pully bore and shaft only, don't put any on the screw threads (you don't need them, and I've known people to end up snapping the screw that way...)
Put the pump on the bench, or in a vice (just snug, not tight. You're using the vise as a "third hand") with wood in the jaws. Set the pully in place, screw the nut about halfway (or a bit more) up the screw, and put the washer on. Run the screw into the pump shaft as far as it will go. Apply grease to both sides of the washer.
Since you've bottomed the screw in the shaft (it's a blind hole in a hardened shaft,) you shouldn't need to use a wrench to hold the screw in place - so just slowly turn the nut down to press the pully on. The pully will stop when it is flush with the snout of the shaft - which is where you want to stop anyhow.
Back up the nut about one turn, then back the screw out of the shaft. Install the pump.
Yes, you could probably install the pully after installing the pump, but why make the job far more difficult than it needs to be?
Old January 7th, 2009, 23:35
ehall's Avatar
ehall ehall is offline
Uh you install the pulley after installing the pump, and remove the pulley before removing the pump. No need for holes in the pulley at all. This is the way my Cadillac is setup BTW, and it uses nearly the same GM pump.
The holes are nice to have if you need to remove the pump often (IE swap the intake or exhaust) but are not critical
my '91 beater rebuild
Old January 7th, 2009, 23:38
ehall's Avatar
yep
Yeah you press it on. There is a thread in the center of the pulley shaft that the supplied bolt goes into, and the nut is used to press the pulley onto the shaft. More specifically, put the pulley on the shaft, put the square nut and washer on the bolt, drive the bolt into the threaded shaft at least an inch (don't take it all the way or it will get stuck), then crank the square nut down to push the pulley onto the shaft.
Old January 8th, 2009, 00:06
Ok, confused which is it... question when the pump is mounted then the pulley... what do I do if I have to replace the pump again with the new pulley has no holes.
Old January 8th, 2009, 06:41
Gerr's Avatar
Gerr Gerr is offline
mount the pump then put the pulley on and get happy with the anti-seize so next time removal is easier
if you have to change the pump again use a puller to remove the pulley first
Old January 8th, 2009, 08:26
FordGuy's Avatar
First, it is a pain in the ass to install the pulley on the vehicle compared to on the bench. Second, to use a good puller to remove the pulley, there is barely enough room and if you ever need to swap it out on a trip or trail, it will be 10 times easier to do it with the correct pulley. They put the holes their for a reason.
Old January 8th, 2009, 08:49
ehall's Avatar
remove the pulley before removing the pump?
Old January 8th, 2009, 08:59
FordGuy's Avatar
Need to use a pulley with holes! You will be doing youself a favor.
Old January 8th, 2009, 09:06
avnsteve's Avatar
avnsteve avnsteve is offline
why would you not reuse the pulley with the holes? is the shaft diameter different, or is it damaged in some fashion?
Old January 8th, 2009, 09:23
this is the dilemma...
as you can see the power steering pump shaft is still attached to the pulley...
new pump on left old pulley with shaft on the right..
SO here is the question do I have to have a pulley with or with out holes??? guy's are really need a definitive answer... I am going crazy here...
Old January 8th, 2009, 09:47
avnsteve's Avatar
go to autozone or your local parts house, buy the proper puller, remove the shaft from your OLD pulley, and REUSE it on your new pump. that solves ALL your problems. Use the same tool to reinstall the pulley on the new pump BEFORE mounting the entire unit under the hood.
Power steering pump pulley rgerber2 OEM Tech Discussion 1 June 15th, 2008 19:32
Wanted: Power Steering Pump w/resevoir and pulley EASportsRacer13 Arizona For Sale/Wanted 0 April 11th, 2008 13:40
power steering pump pulley question dsgray16 OEM Tech Discussion 5 February 3rd, 2007 15:58
Power steering pump pulley Root Moose OEM Tech Discussion 4 November 3rd, 2006 22:28
power steering pulley wek91xj Modified Tech Discussion 15 February 2nd, 2005 11:22
