Old October 26th, 2008, 22:35
Crabapple Crabapple is offline
Auto Transmisson woes
Workin on my friends '95 ZJ 4.0L, we got the tranny, 231 and front/rear driveshafts on today. The Jeep starts and shifts gears fine, but won't move anywhere??! You can shift the 231 from 2WD, 4HI and 2LO just fine. The engine idle varies when you go from say park to drive/reverse or neutral to drive/reverse just like it would normally do underload, but being in gear and hitting the throttle leads you no where. Any ideas? Also guages no longer work.
Old October 27th, 2008, 08:54
jeepman121's Avatar
jeepman121 jeepman121 is offline
Re: Auto Transmisson woes
Are all your wires and sensors connected??
Old October 28th, 2008, 18:12
Yes, all sensors are connected.
Old October 28th, 2008, 20:51
lawsoncl lawsoncl is offline
Did you swap anything out, like the transfer case? Just wondering if perhaps you have mismatched spline counts between the tranny output and the xfer case input.
Old October 28th, 2008, 21:36
The Tranny was changed, but they are identical years and both backed by the 4.0. Spline count was counted aswell.
Old October 29th, 2008, 09:03
JoshRountree JoshRountree is offline
Might be possible the input shaft on the transfer case isn't long enough?
http://www.novak-adapt.com/knowledge...nput_gears.htm
Old October 29th, 2008, 10:13
8Mud's Avatar
8Mud 8Mud is offline
Did you get the torque converter seated all the way into the pump???
Transmisson question: Stallacrew OEM Tech Discussion 10 August 24th, 2008 12:01
Transmisson jeepz NAC Classifieds 1 March 7th, 2007 10:13
transmisson lines chpjeep OEM Tech Discussion 8 January 14th, 2006 17:21
Auto Tranny woes GTIguy02 OEM Tech Discussion 6 October 9th, 2005 20:38
Ideal Transmisson Temp JohnJohn Modified Tech Discussion 2 September 25th, 2004 20:17
