Old October 17th, 2008, 22:18
00XJFAN 00XJFAN is offline
Seat belts not comfortable-Huge family issue
Have a 00XJ and my family complains about the seats belts in the rear seat are very uncomfortable. The lap portion of the belt locks in one position after you buckle and will not give at all to allow you to move around at all. The only one that dosn't do this is the drivers seat belts which has a slightly different end on them.
Anyone have a solution for this?
Old October 17th, 2008, 22:32
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
Re: Seat belts not comfortable-Huge family issue
My 95 doesn't do that but on alot of newer vehicles, I've noticed that the rear belts will do what you describe if you pull on the belt until it cannot go anyfurther and then let it retract..
I think the main purpose is for securing child seats and other cargo.
If you don't pull on the belt until it is at the end of its travel it will allow you to move around without locking.
Unless your mechanism is damaged, then I don't know what to tell you.
Old October 17th, 2008, 22:45
ehall's Avatar
ehall ehall is offline
maybe put the huge family on a group diet
my '91 beater rebuild
Old October 17th, 2008, 22:47
No it's not when you pull it all the way out and it then rachets, anytime you buckle them it wont allow any slack from the lap portion of the belt, the upper part is fine.
Old October 17th, 2008, 23:42
Littlewhitexj Littlewhitexj is offline
all the slack comes from the upper portion, its just a matter of moving that slack through the buckle itself. Are they tangled up or twisted at all?
Old October 17th, 2008, 23:47
No but on all except the drivers when you buckle the belt the end is 2 pieces and it slides to pull tight against the belt. The drivers belt doesn'h have this its just on piece with a fixed opening where the belt goes through. On this belt when you move around the lap belt gives as well as the upper one.
Old October 18th, 2008, 10:11
OverTheHillsATTW OverTheHillsATTW is offline
My friends 99 also does this in the passenger seat. Used to squeeze my gut when offroading.
need seat belts pb_beaker Arizona For Sale/Wanted 1 May 16th, 2007 21:34
Seat Belts Only In A Jeep XJ Modified Tech Discussion 2 March 21st, 2007 19:42
Seat belts too short to install baby seat Headache OEM Tech Discussion 9 September 25th, 2005 08:33
seat belts 85Chief OEM Tech Discussion 9 May 6th, 2004 23:02
seat belts DaveD in Canada Wanted: Private Party Only 2 June 22nd, 2003 18:58
