Old August 23rd, 2008, 11:54
Stallacrew's Avatar
Stallacrew Stallacrew is offline
Transmisson question:
I am thinkng about getting a 1990 with a busted transmission which only has 1st 2nd and 5th gears in hopefully the ax-15 transmission. It has a backup tranny that comes with it which is a whole other story.
I would have to drive the thing 180 miles back home.....could I do it with only those three gears?
I don't know much about manuals (or really automatics) but I need a firm input on this. I think it might work.
Aisin AX15 Gear Ratios
First Gear 3.83
Second Gear 2.33
Third Gear 1.44
Fourth Gear 1.00
Fifth Gear 0.79
Reverse 4.22
Will 1 2 and 5 work?
Thanks guys--Alex
Old August 23rd, 2008, 13:17
souske's Avatar
souske souske is offline
Re: Transmisson question:
well your gonna be doing it in 2nd the whole way 5th is a dog even with 3rd and 4th to get there. can it be done yes, but if you can tow it thats what id do
Old August 23rd, 2008, 13:51
cherokee chuck cherokee chuck is offline
It might just give up the ghost halfway home. You might get stranded in an inconvient place. You should at least have somone with a tow bar follow you in case it breaks, otherwise it might get expensive or even dangerous.
Old August 23rd, 2008, 16:00
lawsoncl lawsoncl is offline
3rd and 4th share a shift rail and fork. I'm thinking maybe a broken shift fork which could mean loose parts floating around. I vote for renting a car dolly and towing it home, even if it's to save the frustration and burning up the clutch trying to slip it into 5th.
Old August 23rd, 2008, 20:53
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
X2, tow it.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old August 23rd, 2008, 22:28
Stallacrew's Avatar
Can I tow an Xj with 5.2L ZJ? I've towed my 200lb boat with it, but never a dollied vehicle. A dollie is no problem but I just wanted to be able to drive the thing. Damn. I really appreciate all the input guys.
When I do get it home could I possibly run it with just 1 and 2 around town and to class? I'll check out what rearend gear it has. It's a 2wd 4cyl 5spd so i would figure 3.07's. I've heard 60 in 2nd, but doesnt seem right.
Old August 23rd, 2008, 22:37
Stihl029's Avatar
Stihl029 Stihl029 is offline
Should be able to tow it...may not be fun though. I have done a few flat tows pulling a kaiser m-715(I know way heavie) w/ my 88 but we made it.
Old August 24th, 2008, 00:27
badron badron is offline
The sticky say 411. If all is as it came from the factory.
YES! for about 2 minutes.
Then 0
FYI the 4 banger came with the AX5. If all is as it came from the factory.
Old August 24th, 2008, 02:14
copper204's Avatar
copper204 copper204 is offline
Red face Re: Transmisson question:
Tow it. By the way with a 4 banger and five speed. sadly you will be getting the dreaded AX5 tranny not an ax15. But they {tranny} are an easy build. Hal
Old August 24th, 2008, 11:39
Rebuild cost will depend on what's broken. He did mention that it comes with a spare tranny. Depending on the age of that, it might be worth it to put a bearing/brass kit in it before installing. Of course, don't use GL5 gear oil as it slowly eats the synchros and shifts like crap. Redline MTL worked fantastic for me.
Old August 24th, 2008, 12:01
Stallacrew's Avatar
Is a manual transmission hard to rebuild in general. I just stroked a motor so I'm no mechanical retard, but I am gonna be at college and wont have the best tools like here at home. I would like to get it and rebuild the good one before I swap it in due to the unknown condition. I know rebuilds get spendy, but since this is a 2nd vehicle and I have a back up I'd like to try to fix some more difficult things if I can.
Super quick question before I head out the door to the Junkyard. 99+ intake Question. Plays For Jeeps Jeep Street and Performance 26 October 13th, 2008 07:25
Transmisson jeepz NAC Classifieds 1 March 7th, 2007 10:13
transmisson lines chpjeep OEM Tech Discussion 8 January 14th, 2006 17:21
Ideal Transmisson Temp JohnJohn Modified Tech Discussion 2 September 25th, 2004 20:17
Transmisson cross support diagrams Anthropy Modified Tech Discussion 3 August 18th, 2003 20:18
