Old June 14th, 2006, 19:15
jeepnuts311's Avatar
jeepnuts311 jeepnuts311 is offline
swapping the 8.25 for a d-35
my moms 95 auto 2wd cherokee ate up its rearend and needs a rebuild or replacement, strength is not an issue on this jeep, it is 100% grocery getter.
i have a dana 35 out of a 1990 xj that i just swapped out for a dana 44.
i will be putting the spider gears back in and i wanted to swap it for the chryco, but the snout of the pinion on the dana 35 is about 3" shorter than the chryco, will i need a driveshaft from a 2wd with a dana 35, or will the stock d/s work?
i know its unusual to swap from stronger axle to weaker axle, but a free down-grade is better than dumping money into a stock axle for a rebuild.
i dont know whats wrong with the chryco, but it sounds like horrible backlash and also bad bearings.
thanks
-tim
Old June 15th, 2006, 13:13
Ex CCS Racer's Avatar
Ex CCS Racer Ex CCS Racer is offline
Re: swapping the 8.25 for a d-35
Old June 15th, 2006, 13:17
MrShoeBoy MrShoeBoy is offline
Swap the 35 in and have the driveshaft lengthened. Making the driveshaft longer shouldnt cost more than $75 and you already have the dana 35. Beats $250 labor to have new bearings installed plus what ever the cost of parts will be.
AARON
Old June 15th, 2006, 13:22
bj-666's Avatar
bj-666 bj-666 is offline
measuer ds length and then go the junk yard and find one for 25$
Swapping in 8.8 into MJ summitlt Modified Tech Discussion 2 August 19th, 2005 11:51
Swapping a 4.0 TB into a 2.5 Camshaft Modified Tech Discussion 4 August 2nd, 2005 19:20
Swapping a 4.0 TB into a 2.5 Camshaft Jeep Street and Performance 0 July 29th, 2005 09:44
Swapping an 88' AW4 to a 91' AW4 BIGWOODY Modified Tech Discussion 3 March 8th, 2005 21:42
swapping 8.8 for D35 BLUTO Modified Tech Discussion 16 July 26th, 2004 07:30
