Old October 20th, 2020, 10:05
RCP Phx RCP Phx is offline
Re: Swapping out to Led's?
Originally Posted by gba88 View Post
After driving it again in total darkness this morning, I'm thinking of desoldering either 1 or 2 of the leds from the front of the unit (the small 74's). They have 3 smd leds on each and they are just way too bright. I'll take 2 of the units to experiment with and see how it goes. I'll have to rig something up to test outside of the car. I really didn't want to switch everything to red so hopefully this works.
Good luck with that, they do make 1smd lamps...
https://www.superbrightleds.com/more...rofit-car/227/
Old October 20th, 2020, 10:55
gba88 gba88 is offline
Already modded 2 of them Made one into a 2 LED and the other into a 1. Just had to bridge the connections when the smd leds were removed. I'll have to get a few in the gauges to actually see what works best.
Old October 20th, 2020, 17:52
Got the cluster out today and got a lot of the pin-out's figured but still missing some. I also broke one of the "illumination" bulbs trying to remove it. Feeling a little burnt out right now from this!
Old October 21st, 2020, 08:23
New day, but continuing with with yesterdays headache. Being a Jeep nothing is simple, last night I had to put in rush order for 30 PC74 sockets as all my lamps are permanently mounted. I still have 5 lamps that I haven't been able to identify the polarity on, I bounce back-n-forth between the FSM and my cluster with a ohm meter. Hopefully today will go better!
Old October 21st, 2020, 17:21
Well, so much for the T3 neo wedge LEDs I ordered...the oem were definitely NOT T3...They must be T5s. I think there must be some light piping going on inside that HVAC panel since there only appear to be 2 bulbs. I removed the leds from the bases I ordered and re-fitted them into the OEM bases. They aren't very bright, I think I need to find an omni directional version for these.
Old October 22nd, 2020, 07:44
I received my PC74 sockets last night and started loading up the cluster. I still had 2 lamps that I could not identify the polarity so I just installed incandescent bulbs in those. I did a test fit last night and it looks great, I will button it all up today!
Old October 23rd, 2020, 07:15
I ran into this....did you have to put the leds in the old brown holders? I found that even if you reverse polarity, sometimes they do not light and you have to rotate the holder 180 degrees. it makes no sense, but I had and issue when I was replacing the ones that i put down to 1 led and was able to get everything working that way. The hvac bulbs should come today. The originals I bought were way too small (T3) and only a single led. The new ones are T10 and 3 leds so hopefully they will work better.
Old October 23rd, 2020, 08:07
I installed 21 leds out of the 23 lamps in the cluster (including the 5 brown socket illumination lamps). Everything worked right out of the box like planned. I did try to look at the AC controls but did not enough slack in the wiring to even "see" the lamps, so I bolted it all up and am calling it good for now.
Old October 23rd, 2020, 18:10
Pretty simple..reach in on the left and unclip the main connector that carries the power, then it will loosen up enough to see the leds... one is on the top and other on the bottom... they are close to the center knob is the best way I can describe location...gray bases and... GUESS WHAT? LEARN FROM MY MISTAKES.... I bought T3s... too small... was convinced they were T5s... TOO BIG!!!! annoying as &!$%! SO...by process of elimination they must be T4s (pic at this link talking about the neo wedge bases) http://www.wardenjp.com/stores/neowedge.html
Anyway, I was able to tear apart a few 194's and transplant the LEDS into the gray stock bases and it works perfect...very bright. I wasted about $20 on the WRONG base styles! I used to mess around with electronics quite a bit so I'll likely find a use for the LEDs in the future it's just annoying since I could have accomplished what I ended up doing without having bought the T3 and T5 versions.
Old October 24th, 2020, 08:04
I finished up the resin job on the 1156's and will install them today and then I'm done. I really have no issues with the AC control lighting. More importantly I want to change over to "led indicator fuses" and then I'll be done with everything. At 61 this has really improved the visibility for me! I'll get pics tonight of the finished interior.
Old October 25th, 2020, 20:05
Both sets of pics were taken at the same time of night with the same camera....
Kick panel before: (barely can see anything)
Kick panel after:
Cluster before:
Cluster after:
Old October 25th, 2020, 20:08
Anak's Avatar
Anak Anak is offline
Stranger
Nice improvement.
My aging eyes appreciate the difference.
Old October 25th, 2020, 21:56
jeep ride's Avatar
jeep ride jeep ride is offline
Big difference worth your time and effort.
Old October 26th, 2020, 02:33
Ralph77 Ralph77 is offline
So I am confused.
That first shot of the cluster.
Is that with the lights dimmed all the way with the headlights on?
Old October 26th, 2020, 07:05
Originally Posted by Ralph77 View Post
So I am confused.
The cluster pics were taken with only the parking lights on, I was getting some glare off the garage wall from the fronts!
swapping aw4 1slowxj Modified Tech Discussion 3 December 30th, 2014 09:07
swapping out a 2.8 to 3.4FI Gregor Modified Tech Discussion 1 February 2nd, 2008 16:20
Swapping in Mj d44. GrapeApe Midwest Chapter 10 July 6th, 2006 22:15
swapping the 8.25 for a d-35 jeepnuts311 Modified Tech Discussion 3 June 15th, 2006 14:22
swapping 8.8 for D35 BLUTO Modified Tech Discussion 16 July 26th, 2004 08:30
