Old October 16th, 2020, 14:51
RCP Phx RCP Phx is offline
Re: Swapping out to Led's?
The other thing that I didn't mention is my led headlights. I didn't do anything but replace the sealed beams, and since then I have DLR's.
https://naxja.org/forum/showthread.php?t=1130887
Old October 16th, 2020, 14:58
Ralph77 Ralph77 is offline
Another thing I pointed out I did not have in the thread.
Old October 17th, 2020, 07:53
JC93XJ's Avatar
JC93XJ JC93XJ is offline
I did all LED interior lights on my 93.
194 for the guages, shifters, under dash
For the climate controls I don't remember the size but was a tiny led bulb.
For the dome lights I used 44feston style bulbs
Really updated the feel of the interior.
They don't dim which I really don't mind. But if I drove alot at night I probably would do the guages in a blue/ green or red so it won't be so harsh on the eyes..
I also did the reverse lights. Those were 1156 size extremely bright. I also changed the licence plate light with a 194.
The side markers are 194 but don't work since you'll need to get a flasher that works with led.
The under the hood light I used one the dome led bulbs.
Old October 17th, 2020, 08:51
Today I'm going to remove the trailer converter and start from there and check all the grounding connections.
Old October 17th, 2020, 11:38
Removing the tail light converter seems to have cured the rear back-feed so this evening I will try re-installing the front leds.
Old October 17th, 2020, 12:52
I tried the fronts again and still bad luck, I'm giving up on them at least for now. I want to focus on the dash and instrument cluster.
Old October 17th, 2020, 16:44
tjmotter's Avatar
tjmotter tjmotter is offline
Once you complete this project you should test the cruise control. Since the newer models use the computer to drive the cruise control you will probably be fine but on a Renix era system, the cruise module needs to see a ground signal when the brake light is off in order to properly set the reference speed. When you install LED's you isolate the ground so it causes a Renix era system to display some very weird behavior like pegging the engine to wide open throttle when you press the set button at 30mph. I don't know that the later models do this but I don't know if they don't so it is something worth checking on a quiet road once you are done.
FWIW, you can adapt the Renix systems to work by installing a relay that toggles between 12V and Ground even with LED's installed.
Old October 19th, 2020, 07:40
gba88 gba88 is offline
Just reporting back and with one question. I replaced the gauges in my 99 with the 74's
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
They are dimmable, but it's maybe only a 5-7% reduction in brightness...I may look for replacements that are dimmer because they are REALLY bright even fully dimmed.
I was able to use 194s for the shifter and 4x4 lever
Now, when I went to do the bulbs in the HVAC panel they were super small so I'll have to look around for those. I think they are "T4/T4.2" from the initial research I did (if anyone can confirm that would be great). I have attached some pics of them. The base seems to be right at 7mm in diameter.
Old October 19th, 2020, 08:00
Now I'm confused ? I haven't done my cluster yet but I was assuming the illumination lamps were 194's and only the indicators with 74's?
Old October 19th, 2020, 08:15
The brown bases in the gauge cluster were definitely the small 74s, there's no way those 194's could have been used...the old small bulbs had to be pulled from the brown bases. The only application I found for the 194s were the shifter bulbs. I'm trying to verify online the TINY ones that are in the HVAC panel, but not 100% sure yet.
Old October 19th, 2020, 08:21
Well... going by this and my measurement, looks like they might be "T3". I sure wish someone knew for sure!
https://www.aliexpress.com/item/1572831055.html
Old October 19th, 2020, 11:14
I just ordered some more 74's just in case cause I don't want to tear my dash down without being ready. I made sure they are dimmable so hopefully I'm good to go. I'm actually getting mine ready to tackle.
Old October 19th, 2020, 12:28
do you have a link? the ones I ordered didn't say directly they were dimmable, but someone mentioned it in the comments.
I went ahead and ordered the following:
I'm positive the ones in the HVAC panel are "neo wedge" T3 bases. I couldn't find any that were dimmable though. I also thought about going with all red ones and doing it all over again since red is much easier on the eyes during the night. Not sure how it would work out though with the areas that have orange print.
Old October 19th, 2020, 16:23
This is what I ordered for 74's for instrument illumination ......
https://www.superbrightleds.com/more...-car/228/1067/
Old October 20th, 2020, 08:56
After driving it again in total darkness this morning, I'm thinking of desoldering either 1 or 2 of the leds from the front of the unit (the small 74's). They have 3 smd leds on each and they are just way too bright. I'll take 2 of the units to experiment with and see how it goes. I'll have to rig something up to test outside of the car. I really didn't want to switch everything to red so hopefully this works.
swapping aw4 1slowxj Modified Tech Discussion 3 December 30th, 2014 08:07
swapping out a 2.8 to 3.4FI Gregor Modified Tech Discussion 1 February 2nd, 2008 15:20
Swapping in Mj d44. GrapeApe Midwest Chapter 10 July 6th, 2006 21:15
swapping the 8.25 for a d-35 jeepnuts311 Modified Tech Discussion 3 June 15th, 2006 13:22
swapping 8.8 for D35 BLUTO Modified Tech Discussion 16 July 26th, 2004 07:30
