Old March 6th, 2019, 08:35
TheWeeWaggy TheWeeWaggy is offline
Re: BUILD - 1990 XJ Wagoneer Limited
Oh man that's some muddying of the waters!
Old March 6th, 2019, 09:26
Anak's Avatar
Anak Anak is offline
Stranger
I am happy to see the progress you are making on this.
Kudos to you for rescuing this one.
Old March 6th, 2019, 15:40
It's a labor of love, that's for sure, and thank you! I always loved these things. I was more interested in the GW (and still want one for my non-existent, but officially started now jeep-hoard), but this one was a right place right time sort of deal. Parts are tough to find though. Tougher than for a GW I'm finding.
It's been at the body shop since November, which has been really good for us. Not being in a rush, and getting to do a lot of the work ourselves (like prep stuff) has been a good learning experience, and has saved us a LOT of what would've been a really big bill. It's still a big bill, but not what it was.
The other side should be painted this week, and the floorpan will likely be replaced before or right after. After that, it comes home and I start picking through it.
I need to figure out where the heck to begin. There's a big part of me that just wants to start rebuilding the whole thing, wiring and all. It's still a huge project, but definitely snatched from the jaws of death.
I'm really happy to have found this community. Up until this point I've always been a Wrangler guy. Had a 1990, and have a 2013 now. Had a 2000 XJ and 2004 WJ for work purposes, but those are long gone now. But just goes to show you, Jeeps are in the blood I suppose. Doesn't matter what kind. Why else would someone (or many someones) spend this kind of time and money on an old pile like this, LOL.
Old March 11th, 2019, 07:06
Some paint progress pictures! The roof is all straightened out now, hail damage removed. Passenger side is painted now. Is it wrong to kind of dig the white top and hood with the blue?
Old March 13th, 2019, 20:05
BALTANAKT BALTANAKT is offline
Looking sweet. What's the plan for the roof & hood?
Old March 16th, 2019, 10:50
It'll all be the same color eventually!
Ordered some sound deadening material for the inside as well. Should be here today I think.
Old April 29th, 2020, 08:00
loseit loseit is offline
Did we ever see the end of this build/ restoration? Would love to see how the interior etc came out
Old June 15th, 2020, 09:26
Hey there!
Not yet. It's far from over, LOL. It's just been on the shelf for a bit with current events. I guess the Waggy has been quarantined along with everyone else.
The current status is that it's painted now. We have the wood appliqué/trim for the sides, but it's not on yet.
I sent off the border trim for the appliqué on the sides to be re-wrapped - hopefully that will be back by the end of this month. Once we have that, we can put the thing back together and bring it home from the body shop.
I reached out to a local upholstery shop to get a quote on doing the fabric inserts on the seats, the headliner, and the cloth parts of the door panels. Since the interior of the Waggy is out of it, I could just leave everything with them. Might as well while no one is driving it.
Once it's home - the agenda turns to putting it back together. I need to find a few trim pieces (but man I can barely remember now without seeing it), decide on interior carpet since we threw the old nasty carpet out (and it was NASTY).
Before carpet I'll probably POR15 the interior for good measure, then apply sound deadener. I'm considering trying to have the undercarriage blasted and coated, but I'm not sure. This isn't a frame-off resto at this time, so I'm not sure if it's worth it.
I suppose I should decide if I want to tackle redoing ALL the wiring in it while it's apart. The wires appear to be in good shape still, but they're also 30 years old. I don't like the idea of it.
Beyond that it'll be mechanical concerns. Still a long road to go.
Old June 16th, 2020, 21:08
Anak's Avatar
Stranger
FWIW, I think AMC did a much better job with wiring than did Chrysler.
I say this based on my experience with the wiring for the fan switch for the HVAC system. The 4 prong connector in the dash always seems to be melted down on the H.O. XJs, but I can consistently find them in good condition in Renix XJs.
IOW, I would be slow to ascribe Chrysler's faults to AMC. Have good reasons before you tear into that wiring.
Old June 24th, 2020, 08:31
Wise words I'm sure. Also under the banner of if it ain't broke, don't fix it.
The wiring looks ok. Old, but ok.
Old June 24th, 2020, 09:10
lawsoncl lawsoncl is offline
I'd probably just inspect the wiring real well for damage, and maybe pop apart connectors that get wet or carry current to clean and inspect. The fusebox and connector behind it for example. A headlight relay harness is always a good idea. Go through the cruiser54.com site and follow all the steps on the grounds, etc.
Then again is was AMC that did that problematic C101 connector and the headlight wiring and switch that likes to meltdown.
Old June 24th, 2020, 16:40
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Most definitely do a relay harness for the headlights - your headlight switch will thank you, and you'll get much better light output from the bulbs.
While a relay harness for this is not "stock", it should have been.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old June 27th, 2020, 06:47
AAubinoe AAubinoe is offline
Wow its cool you are redoing that wagoneer. I have a 89 and a 90 that I hope to make one good one out of, also taking the more damaged front clip off and putting it on my 2000 Trail Jeep.
One thing I found strange is that he did not remove the rear glass, or the front fenders for paint. My 1990 is dark blue, but rusted beyond repair, but has a good engine and fuel system. The 1989 has a nice body but a bad knock. Sometimes things work out!
Old August 13th, 2020, 13:20
Thank you for that advice. I'll research it. I'm generally a dummy with wiring unless it's run-and-connect, LOL, but I think I can figure a relay out.
Brighter headlights will be nice. When we were first running it around we got into the dark here and there. After being used to modern era headlights the Waggy's left a bit to be desired. If I can find LEDs that won't change the look I'll go with those. I know LEDs become a slippery slope very fast on an older car.
More than likely it'll come down to improving the existing hardware, though.
Old August 14th, 2020, 07:06
Anak's Avatar
Stranger
You can get housings that have better beam patterns and take modern bulbs and won't change the look.
1990 Jeep Wagoneer Limited andysobo OEM Tech Discussion 3 January 12th, 2016 09:52
1990 Jeep Wagoneer Limited Problems overflow OEM Tech Discussion 9 February 18th, 2009 15:58
1990 Wagoneer Limited- lower control arm mount broken Kyle_South_Park OEM Tech Discussion 2 February 16th, 2009 06:43
1990 Wagoneer Limited XJ Fender Issue Kyle_South_Park Paint and Bodywork forum 4 February 7th, 2009 18:39
