Old August 26th, 2018, 07:19
bobhouseholder bobhouseholder is offline
2000 xj loud noise at start of crank - no start
Hi,
My 2000 xj will not start.
- checked most grounds but need to check and clean the remaining
- new battery from before
- no codes thrown
- new starter
- same problem in neutral (probably not the neutral position sensor)
When I go to start I can hear the right sequence in the key position right before ignition. When starting it cranks maybe once then I get a loud sound and then nothing.
have not tried:
- jump while starting...maybe battery is drained
- CPS ... but no codes thrown
I have searched this and other forums but have not found the same problem reported.
Thanks,
-Bob
Old August 26th, 2018, 07:29
RCP Phx RCP Phx is offline
Re: 2000 xj loud noise at start of crank - no start
It could be lots of things, your going to need lots more info. Scanner data, voltages, audio, video and more are all needed to help with the diagnosis.
Old August 26th, 2018, 07:45
Can do. First post so I need to find out how to upload vid to hear sound.
Old August 26th, 2018, 10:09
Tried to start with a jump with no change.
13.34V on battery when hooked up to second car.
12.48V battery at rest
Link to vid below for loud sound at crank.
https://photos.app.goo.gl/gvB8GhXqCVAYyQKa9
Old August 26th, 2018, 11:03
That's the bendix on the starter.
Old August 26th, 2018, 11:08
The starter is new. Do I need to give it a whack to engage?
Old August 26th, 2018, 11:21
It needs changed, if it's new warranty it! What brand was it?
Old August 26th, 2018, 11:24
Premier gear. New with warranty. Will pick up name brand at auto part store then. Thanks!
Old August 26th, 2018, 11:26
Is a rebuild generally okay? Car quest from advanced auto?
Old August 26th, 2018, 15:43
It was not the starter as a second one has same noise. Thoughts?
Old August 26th, 2018, 16:02
techno1154's Avatar
techno1154 techno1154 is offline
Flywheel ring gear missing a tooth or 2,... Put a socket wrench on the vibration damper bolt on the front f the engine and turn it just a little then try the starter.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old August 26th, 2018, 16:07
That sucks, a flex-plate is a major project.
Old August 26th, 2018, 17:40
trippled trippled is offline
I would also check and make sure you always have battery voltage at the solenoid control wire when the key is in start position
Old August 26th, 2018, 18:16
update:
- not able to get engine to turn over after rotating a bit...tried several times in case I was still missing some gears
- looked at other new starter that was removed and it looks fine...thinking maybe I sheared off gears on that one
- I have battery voltage both without and with the key in the first position across the solenoid
Old August 26th, 2018, 18:45
update:
- found and tested against some of this checklist
https://www.cherokeeforum.com/f59/no...cklist-155216/
- checked a few fuses and do not see anything broken
- did test for ignition switch and that is okay (would not expect this to be the problem)
- not able to check fuel pressure
- hear fuel pump come on during startup
2000 XJ Crank NO START coreyt OEM Tech Discussion 2 February 8th, 2017 03:45
2000 crank no start - chime while cranking tomcat OEM Tech Discussion 7 April 23rd, 2013 16:56
Loud noise on start up and shut down. Video for reference ruger81 OEM Tech Discussion 5 March 10th, 2013 18:29
2000 XJ Slow Crank sometimes No start jamesonw23 OEM Tech Discussion 5 January 9th, 2012 14:33
crank-crank-crank-crank-cra... [wait...] crank-crank-START! iBran OEM Tech Discussion 20 October 21st, 2005 17:33
