Old January 4th, 2016, 10:46
andysobo andysobo is offline
1990 Jeep Wagoneer Limited
Hi everyone, I am new and already like this site. My question is on my 90' Wagoneer Limited my instrument cluster stopped working. Purchased a used one and same problem. Now going after the instrument panel relay but not sure where it is under hood as there are other relays near it. Can anyone help and/or a diagram of the relays under the hood. Thank you in advance.
Andysobo
Old January 4th, 2016, 17:16
8Mud's Avatar
8Mud 8Mud is offline
Re: 1990 Jeep Wagoneer Limited
There is no instrument panel relay. Check your gauges fuse for voltage, both sides of the fuse. Check the white wire with a black stripe at pin 6 on the instrument cluster connection for voltage with the key in the run position.
Check your ignition switch connector for scorching.
If all the gauges are out it is likely to be a voltage in problem and not a ground problem.
Old January 6th, 2016, 15:43
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Good advise!!!!
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old January 12th, 2016, 09:52
Thank you for the info. I will check and get back to you.
1990 Jeep Wagoneer Limited Problems overflow OEM Tech Discussion 9 February 18th, 2009 15:58
1990 Wagoneer Limited- lower control arm mount broken Kyle_South_Park OEM Tech Discussion 2 February 16th, 2009 06:43
1990 Wagoneer Limited XJ Fender Issue Kyle_South_Park Paint and Bodywork forum 4 February 7th, 2009 18:39
maximum tire size on a stock 1990 Jeep Wagoneer Limited (XJ BODY) jeepxjfan2004 NorthWest Chapter 25 March 16th, 2007 10:30
