Old December 22nd, 2014, 08:00
1slowxj 1slowxj is offline
swapping aw4
ive got a 88 xj with a 94 trans behind it the input shaft pushing is shot and is pouring out transmission fluid like crazy cant keep front pump seals in the thing ive got a few different options i can pick up a 97 trans with transfer case and convertor cheap i can also pick up a 99 with driveshafts and sye installed for same price so i would like too go that route reading into it seems that i would have to try to adapt output speed sensor? now i dont really care about speedometer seems how it was cable driven and doesnt work anyways but not sure if this is the one the trans control module uses to determine shift points and such and thats a little more important to me.. seems 97 swap would be cake not really sure what route to go and if there was simple way to make swap happen? any ideas?
Old December 22nd, 2014, 09:18
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: swapping aw4
The 97 trans would work, the 99 would not.
The wiring on the 97 is not the same, you'd have to cut the plug off and wire teh plug from your existing bad trans onto the 97 trans. The colors IIRC are all the same, so it should be pretty easy.
Old December 30th, 2014, 06:46
Re: swapping aw4
alright ive got the trans bolted up turns out wiring is all different colors got any ideas or diagrams?
Old December 30th, 2014, 08:07
cal's Avatar
cal cal is offline
Re: swapping aw4
Gimme your email addy.
Swapping an '86 2.8 for an '87 2.5 Kman1983 OEM Tech Discussion 0 October 18th, 2008 18:24
Swapping in a 4.7 ponyracer1 Modified Tech Discussion 11 October 17th, 2006 06:16
Swapping in 8.8 into MJ summitlt Modified Tech Discussion 2 August 19th, 2005 11:51
swapping in an aw4......... jmaxj Modified Tech Discussion 4 January 31st, 2004 18:45
Swapping out a D35 with ABS?? ChuckstrPT Modified Tech Discussion 18 January 18th, 2004 20:58
