Old March 13th, 2010, 22:12
islandbum's Avatar
islandbum islandbum is offline
transmisson shifting question
I have a 1992 xj 4.0 it is my dd. I drive in stop and go traffic most of the time. Most of the time just about the speed and rpms for the trany not to shift. (2500 rmps) is there anything I can do about this, besides drive faster.
Old March 13th, 2010, 22:56
joe_peters joe_peters is offline
Re: transmisson shifting question
So what is the question?
Do you want to make sure everything is adjusted and working properly, or do you want manual control of the gears?
Old March 14th, 2010, 06:00
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
Yea, kind of cloudy on your post. Are you saying that the shift points don't appear correct? (too high of rpm before shifting?)
Is fluid fresh? Level correct on the dipstick?
Test your throttle position sensor. It is directly related to transmission performance. It can be tested with a meter and a manual.
Be sure your cable is adjusted properly. Here is a link to a thread that illustrates an easy verification.
http://www.naxja.org/forum/showthread.php?t=1015963
Old March 14th, 2010, 18:21
islandbum's Avatar
Sorry guys. It just seems to always be right at the point of shifting. All fresh fluids and a new throttle position sensor.
I guess I just over think things.
I did adjust the cable a few minutes ago and will be going out later I will let you know how it works
Old March 14th, 2010, 18:29
No problem. I see you are in Cozumel Mexico. Have a few cervezas for us!
Old March 14th, 2010, 22:51
islandbum's Avatar
Did the adjustment and shifts a little better just need to change my driving habits and let it shift when it wants to.
Thanks again I always get good advice here.
shifting question poomero OEM Tech Discussion 4 December 28th, 2009 16:38
AW4 Shifting Question 99XJLove OEM Tech Discussion 26 September 8th, 2009 00:59
Transmisson question: Stallacrew OEM Tech Discussion 10 August 24th, 2008 12:01
Transmisson jeepz NAC Classifieds 1 March 7th, 2007 10:13
transmisson lines chpjeep OEM Tech Discussion 8 January 14th, 2006 17:21
