Old October 13th, 2009, 20:03
WeeTodd's Avatar
WeeTodd WeeTodd is offline
1991 XJ Will not start HELP!!
Ok so I just got a 1991 Cherokee inline 6 4.0L HO for $300 It was not running when I got it and is still not running.
I'm stumped it has all the things it needs to run but it won't.
I have a new fuel pump. I checked the fuel at the rail and there is pressure
I have over 120 psi per cylinder
I have spark at all 6 cylinders
and I have air
I think the timing may be out but not sure how to change it or if it is even possible
so I have all the things I need to run but it does not run
I tried changing the ecu but that did not help
I also unplugged the CPS and then there was no spark and reconnected it and the spark came back.
I TDC the crank and the rotor and cap line up with #1 cylinder
I also tried quick start and that did nothing so itís not a fuel problem cause I could smell it on the plugs when I pulled them
Old October 13th, 2009, 20:14
joe_peters joe_peters is offline
Re: 1991 XJ Will not start HELP!!
Air, fuel, compression, spark--what else could you ask for? Having all of the above at the right time and place.
Check the CPS/CMP (camshaft position sensor), it provides a synch signal for firing the injectors.
Have you tried a NOID light to see if the injectors are in fact firing?
Old October 14th, 2009, 08:10
tims92xj tims92xj is offline
I'm not sure about the 91 but on my 92 inline 6, timing is not adjustable. According to chilton/haynes manuals, timing is only adjustable on the 4 cylinder and v6.
Oseberg posted this link to help me with a timing issue. See if this helps:
http://www.go.jeep-xj.info/HowtoEngineInstall4.htm
Old October 14th, 2009, 09:14
winterbeater's Avatar
winterbeater winterbeater is offline
Even though timing mark and cap/rotor line up, the distributor could be 180 degrees out of phase with the crankshaft. It has to be TDC on compression stroke. This can be verified by checking at the spark plug hole for pressure or removing valve cover and checking that #1 exhaust and intake valves are closed.
Old October 14th, 2009, 12:17
trinappa trinappa is offline
If there is no crank maybe the crank position sensor
Old October 17th, 2009, 10:12
WeeTodd's Avatar
Can you tell me what a NOID light is??
Old October 17th, 2009, 10:27
wim hoppenbrouwers's Avatar
wim hoppenbrouwers wim hoppenbrouwers is offline
Hallo, (sorry Joe)
A noid light is a little lamp or led to see or the wiring to the injector is giving an electric pulse.
wim
p.s. Thanks to McQue
Old October 17th, 2009, 10:31
It is a flashlight used by the Domino's Pizza Noid.
A noid light is a small device used to test the fuel injection signal to a single injector. The signal can't be read by a normal test light or multimeter.
http://www.google.com/imgres?imgurl=...ed=0CA8Q9QEwAQ
Old October 17th, 2009, 17:00
WeeTodd's Avatar
Installed a new CPS
Checked if it was 180deg out of phase it is not
Installed a used rotor/distributor/cam shaft sensor
and it wont fire!!!!
there must be something up with the timeing I spray quick start in it and nothing happens so it is not a fule problem!!!
I just dont know????
Old October 17th, 2009, 17:09
Installed a new CPS
OK, back to basics.
Hook a multimeter to the battery terminals. What is the static voltage?
What is the voltage when cranking?
Old October 17th, 2009, 18:28
WeeTodd's Avatar
OK, back to basics.
12v static
11v cranking
Old October 17th, 2009, 18:38
12v static
11v cranking
Ok, that is good. Reason I asked is you can have plenty of amps for cranking but too little voltage for the engine's electronics. Less than 9 volts things don't work like they should.
Again, basics.
Condition of the spark? Blue, really snaps or yellow?
Old October 17th, 2009, 19:11
WeeTodd's Avatar
Spark looks good nice and blue
Old October 17th, 2009, 19:14
WeeTodd's Avatar
I also unpluged the
MAP no change
IAC a couple times it woud fire while I am cranking but woud not start
TPS no change
unpluged all of them Nothing
Old October 17th, 2009, 19:41
I also unpluged the
MAP no change
TPS no change
Ok. You are saying it is firing when cranking but dies when the key returns to the RUN position?
1991 XJ 4.0 HO What to do.... 1991xjbeater OEM Tech Discussion 25 January 12th, 2009 04:36
Wont start; Rough Idle and then stalls when it does start MudslinginXJ OEM Tech Discussion 17 February 24th, 2008 07:30
A short kills my Battery right after start up. it will only start with a jump help! paxj1112 OEM Tech Discussion 4 June 30th, 2007 20:22
No start...has me stumped (searched the no start threads and I'm a little confused) mdwatkins OEM Tech Discussion 27 November 3rd, 2006 23:28
'88 Chief Rough Idle or No Start or Perfect Start Hawaiian Style OEM Tech Discussion 8 June 9th, 2003 14:51
