Go Back   NAXJA Forums -::- North American XJ Association > Bargains and Deals > Wanted: Private Party Only
Wanted: Private Party Only Post what you are looking for. If it even smells commercial, your ad will be deleted.
Old September 24th, 2009, 11:44
85xjwoody's Avatar
85xjwoody 85xjwoody is offline
power steering pump resevoir needed
It would need to fit my 93 cherokee with the 2.5 engine. Thanks for looking.
Old September 24th, 2009, 19:36
Muddy Beast Muddy Beast is offline
Re: power steering pump resevoir needed
I have one for a 4litter if it's the same...?
~Scott
Old September 25th, 2009, 12:21
85xjwoody's Avatar
Nope, won't work. They are different from a 2.5 to a 4.0. Thanks anyways though.
Old September 27th, 2009, 08:31
XJ&CHZ4ME's Avatar
XJ&CHZ4ME XJ&CHZ4ME is offline
KIM, I knew where a 4 cyl that was like an 86/87 model was. I will check to see if he still has it and if he will part w/ it.
Old September 27th, 2009, 15:07
85xjwoody's Avatar
I am not sure but I think it has to be 91 or newer with the MPI four banger. I guess it don't matter as long as it is a resevoir with two hoses coming out of the bottom. I will try and get a picture up tonight.
power steering pump/pulley help needed cdnabn49 OEM Tech Discussion 25 January 9th, 2009 08:14
Power steering pump???? jdxj OEM Tech Discussion 2 November 12th, 2008 21:24
Wanted: Power Steering Pump w/resevoir and pulley EASportsRacer13 Arizona For Sale/Wanted 0 April 11th, 2008 13:40
Power steering pump? Jeepcreep OEM Tech Discussion 18 February 8th, 2008 19:07
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 13:38
