Old October 6th, 2020, 19:33
Unclewolverine Unclewolverine is offline
Most comfortable seats?
I've never had an xj with leather before my 95 and honestly I don't like it. Ive usually owned 96's for some reason, all cloth, and remember their seats being more comfortable. Sitting in these leather ones for 6+ hours a day, only getting out a few times sucks, they don't breath at all. In your opinion what are the most comfortable junkyard seats? Not asking about several hundred dollar upgrade aftermarket seats, just ones I may be able to pick up in the local junkyard cheaply. Not worried about the back matching either, it spends most of its time folded down anyway.
Old October 6th, 2020, 20:41
89Mock 89Mock is offline
Re: Most comfortable seats?
An X5 would be pretty comfortable. One just hit my yard. I also saw a 2012 Jeep there that had full interior but I didn’t have tool to remove them. Maybe a Mercedes E class too.
Old October 6th, 2020, 21:22
jeep ride's Avatar
jeep ride jeep ride is offline
I replaced my xj seats with a set of cloth seats from a 94 zj they are pretty comfortable although the seats do sit about an inch higher up than before.
Old October 6th, 2020, 22:54
maxbraketorque maxbraketorque is offline
I'd like to have a set of seats that are about an inch lower. I'm getting really tired of having to either duck my head by a huge amount to get into the vehicle or angle my body so that my head goes in first. I never thought of an XJ as a small vehicle until I bought it.
Old October 7th, 2020, 08:12
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
ZJ or WJ are comfortable and bolt to the factory rails on a 95+
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old October 7th, 2020, 10:27
Any idea if these sit lower or higher than XJ seats?
Old October 7th, 2020, 10:32
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
A tad higher, but then again they are a much better padded seat. They are very comfortable. I bought some 10 years ago, and they are showing it. Any other WJ seats out there will be in pretty much the same condition.
If you are still looking at WJ seats, go for the Laredo trim package seats. They have an actual reclining lever, as opposed to the power reclining option. One less thing to deal with....
Old October 7th, 2020, 15:51
True. I had Limited seats mounted in my 98, on the XJ manual rails. Ended up with power recline and manual back and forth.
John V.
RRC VP
Old October 7th, 2020, 19:18
Jim Malcolm Jim Malcolm is offline
Looking for seats with less lumbar support but also can't go any higher either. Outer bolster on the driver's side is starting to tear; going to have to find replacements before too long, great timing for this thread. If anyone can suggest options with less lumbar support, my lats/ribs would appreciate it.
Old October 8th, 2020, 10:08
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Hyundai Tiburon? Was a thread on here somewhere in the past year about someone using those...
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old October 8th, 2020, 11:14
Black1990jeep Black1990jeep is offline
My 1990 XJ laredo has some nice seats, back is flat, not all lumbar, nice side bolsters. I recently swapped them for like from a two door as I have a four door. the two door ones fold forward, which is nice for added sleeping room in the back.
Old October 12th, 2020, 05:26
jpk's Avatar
jpk jpk is offline
I have a set of stock leather seats in my 96 XJ and I find them very comfortable. More so than the luggage cloth seats that were in it before. I still have the cloth covers in case I want to revert but I don't think I will.
Most comfortable 4-5" lift, primary street use Dest Modified Tech Discussion 19 December 21st, 2017 21:14
Need a more comfortable ride... ZenDragon Modified Tech Discussion 15 June 29th, 2015 09:40
ZJ or WJ Seats. Which are more comfortable? MRFD715 Modified Tech Discussion 8 June 1st, 2010 13:02
Seat belts not comfortable-Huge family issue 00XJFAN OEM Tech Discussion 6 October 18th, 2008 10:11
'86 2.5L TBI MJ Won't start now (Get comfortable) SilverMJ OEM Tech Discussion 16 March 3rd, 2004 20:53
