Old January 11th, 2020, 13:26
WVjeepr WVjeepr is offline
NP 231 shift problem
1990 Jeep Cherokee My shifter won't move to the right to allow it to go back into 4 low. Is this a problem with the linkage under it or the shifter assy. itself?
Old January 11th, 2020, 14:15
RCP Phx RCP Phx is offline
Re: NP 231 shift problem
It would be in the shifter assembly itself.
Old January 12th, 2020, 07:45
so is there anything that can be fixed in the shifter assy to repair it or should I just replace it? Wish I had on to look at to see it function to figure it out
Old January 12th, 2020, 07:57
Here's a RHD unit with pics, it will give you a idea as to what to look at.
https://www.quadratec.com/p/omix-ada...ep-cherokee-xj
Old January 12th, 2020, 08:11
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Typically the 4x4 shifter linkage is out of adjustment, out of alignment, or the bushings have failed.
Adjust the linkage, inspect for misalignment and failed bushings. Install fresh bushings, or upgrade to an aftermarket shift mechanism.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old January 12th, 2020, 09:55
what an overly complicated system for such a basic concept. I can try the shifter over to the right and pull it back into low will have to tear it apart and see what's up. Thanks for the info.
Old January 13th, 2020, 18:14
denverd1 denverd1 is offline
Stock linkage sucks big time. Couple folks make aftermarket replacements.
Old January 14th, 2020, 08:05
devildog0's Avatar
devildog0 devildog0 is online now
The part that allows the shifter to move left and right isn't in the linkage under the Jeep it's in the shifter assembly. If you look at the diagram the handle has a round piece that goes into the pivot point that allows the shifter to go front and back. I've seen more than one shifter where the left right pivot is simply corroded and frozen in place. I've been able to get the to loosen up by applying penetrating lubricant and some force.
On the upside if you can't get it to free up there's plenty of shifter assemblys out there
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old January 14th, 2020, 11:39
HotBox HotBox is offline
Is it too basic for me to ask... did you shift the transmission into neutral before trying to shift the tcase into low range?
ax-15 shift problem thatguytrav OEM Tech Discussion 6 June 22nd, 2009 07:04
2LO shift problem Cipey Modified Tech Discussion 0 June 24th, 2008 12:35
aw4 shift problem Ron Hyslop OEM Tech Discussion 0 December 22nd, 2007 11:37
1-2 shift problem deanonasset Modified Tech Discussion 2 April 23rd, 2007 18:53
shift problem ken johnson OEM Tech Discussion 0 February 24th, 2005 17:27
