Old January 7th, 2020, 21:39
RCP Phx RCP Phx is offline
Any brand recommendations on a replacement oil pan?
As the title states.......
Old January 8th, 2020, 00:24
bajabronco bajabronco is offline
Re: Any brand recommendations on a replacement oil pan?
Ron, I bought the Spectra one for my stroker build, seems to be made well.
https://www.amazon.com/Spectra-Premi.../dp/B000C7TTCQ
Old January 8th, 2020, 06:22
Thanks Mark, I just need a good clean one that I can weld on and I don't want to be down long.
Old January 8th, 2020, 11:52
blu3fan's Avatar
blu3fan blu3fan is offline
doesnt matter which u buy honestly...
Just don't do what I did.
I bought one where the oil drain plug came stripped and I didnt check it til it was installed and I removed it to drain the oil.......
Its been a nightmare since.
Check the darn oil threads are not ruined....
Old January 8th, 2020, 12:21
What brand did you buy? I didn't think about ordering a drain plug!
Old January 13th, 2020, 18:55
My oil pan will be here tomorrow, I went ahead (although they're pricey) and bought a genuine Mopar pan to eliminate any issues of fit-up.
Old January 13th, 2020, 19:23
denverd1's Avatar
denverd1 denverd1 is offline
What's the purpose of welding the pan on?
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old January 13th, 2020, 19:24
https://naxja.org/forum/showthread.php?t=1156848
Old January 13th, 2020, 19:33
denverd1's Avatar
Kinda odd for an engine that's known to last 300 to 400k miles with regular maintenance
What makes you think your engine is oil starved?
Chili Pepper '98
Old January 13th, 2020, 19:40
All engines see their most wear at start-up and with a 10k stroker you kind of want to protect that(plus there is the thought of a Turbo which requires after-oiling).
Old January 14th, 2020, 07:13
CMNCHE's Avatar
CMNCHE CMNCHE is offline
Forgive my ignorance on this pre and post oiling subject, but I have yet to see a big rig turbo with an after oiler on it? Whats the necessity?
Old January 14th, 2020, 07:38
Big rigs let their turbo's cool down by letting them idle for along time while car drivers tend to just shut it off.
Old January 15th, 2020, 19:27
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
I know this would be redundant in this particular application (seeing as how he's already got the oil pump going in), but wouldn't an after run coolant pump be better for a turbo?
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old January 15th, 2020, 19:29
It's the same installation, only the electrics change.
Left hand drill bit, need brand recommendations? 4x4JeePmaNthINg Tools and Garages 7 December 12th, 2019 08:57
Stock shackles brand recommendations? solomon7 OEM Tech Discussion 5 September 5th, 2018 00:50
H4 Headlight Brand recommendations??? Redsnake OEM Tech Discussion 17 December 15th, 2009 13:10
replacement shock recommendations anotherjeff Modified Tech Discussion 5 April 14th, 2008 12:44
Brand of gear oil recommendations? 2001XJ Modified Tech Discussion 7 May 8th, 2007 19:03
