Old October 3rd, 2006, 14:15
LABMBA87's Avatar
LABMBA87 LABMBA87 is offline
NEW JEEP OWNER
JUST BOUGHT A 94 CHEROKEE. 4 INCH RUBICON, WITH 31'S. NOT NEW TO WHEELING, BUT NEW TO JEEPS. ANYBODY WITH ANY SUGGESTIONS WITH ANYTHING I CAN DO?? ALSO, ANYBODY GOT A GOOD PARTS HOUSE WHERE I CAN GET DECENT PARTS FOR CHEAP? THANKS
NEW JEEPER IN OREGON
Old October 3rd, 2006, 14:17
Skullver's Avatar
Skullver Skullver is offline
Still Flailing
Re: NEW JEEP OWNER
welcome and please STOP YELLING, try searching around and figuring out what you want to turn it into and then form some more specific questions, nobody should be able to tell you what you want to do with your rig.
LilRhodyXJ's Avatar
LilRhodyXJ LilRhodyXJ is offline
Re: NEW JEEP OWNER
you could search and not use all caps
o and welcome
Old October 3rd, 2006, 14:45
LABMBA87's Avatar
Re: NEW JEEP OWNER
Sorry bout the caps. At work with a program for all caps. Fixed. Any how, thanks for the tips. One question- my trac-bar is loose and there doesn't seem to be a drop bracket as per the witness marks on the bracket. what's the best way to fix this pop everytime i turn right?
Old October 3rd, 2006, 14:55
87manche's Avatar
87manche 87manche is offline
Re: NEW JEEP OWNER
tighten the trackbar bracket.
if that doesn't work check the bushing on the axle end.
If the bushing's good check the TRE at the frame side.
if the TRE is gone you'll be buying a new trac bar.
Don't forget to check all the TRE's in the steering system, and the control arm bushings, they have a habit of making clunking noises when they're not right.
Old October 3rd, 2006, 15:11
LABMBA87's Avatar
Re: NEW JEEP OWNER
someone told me to drill it out and move it over? is this half-assed or what?
Old October 3rd, 2006, 15:14
Skullver's Avatar
Still Flailing
Re: NEW JEEP OWNER
that is only if your trackbar is too short, which it isn't if your axle is centered. And that is half assed but works if you can't afford a longer/adjustable tb
Old October 3rd, 2006, 15:17
LABMBA87's Avatar
Re: NEW JEEP OWNER
alright, so new trac-bar or shitty axle position? hmmmmm tough one. need to align after replacing tb? i would assume so? thanks for the input.
New (to me) 97 XJ Owner tonrow OEM Tech Discussion 10 March 4th, 2006 16:14
I am now a xj owner! OffRoadOhio Non-Tech / Off Topic 6 January 2nd, 2006 17:38
New Jeep owner pacexj South East Chapter 4 July 27th, 2005 14:08
New jeep owner :) XJ40 OEM Tech Discussion 1 May 19th, 2005 19:00
New MJ owner and have some ???? catmandu Modified Tech Discussion 8 February 7th, 2004 10:22
