Old April 22nd, 2006, 13:44
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Renix era Oil filter
Spec--87, 4.o 5 spd
The question is should the oil filter drain itself dry overnight ? I am use to the filters in the HO engines,they retain oil because of the horizontal position.The Renix era filters are vertical and does this cause them to drain out or do I have a problem with mine?
Wayne
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old April 22nd, 2006, 13:55
langer1's Avatar
langer1 langer1 is offline
Re: Renix era Oil filter
The correct filter has a anti-drainback valve.
Old April 22nd, 2006, 14:00
Well i,m using a puroilater 14619 ,It was dry when I unscrewed it ,after it set overnight.Nothing ran out/over the block.
Wayne
Wayne
Member#17
anyone in cali swap a HO in a renix yr and pass smog like its a renix? RWKHausSupply Modified Tech Discussion 8 January 30th, 2006 14:55
Still have oil in air filter.... gr8tires OEM Tech Discussion 4 April 24th, 2005 08:24
Renix to HO oil Filter mount TUFFXJ Modified Tech Discussion 4 March 24th, 2005 15:00
Air Filter Simple Green Modified Tech Discussion 1 September 5th, 2004 21:05
oil filter for renix itzak OEM Tech Discussion 1 January 22nd, 2004 15:04
