Old March 23rd, 2005, 12:26
TUFFXJ's Avatar
TUFFXJ TUFFXJ is offline
Renix to HO oil Filter mount
This is a simple question, I currently have a Renix I6 and I know that the oil filter mount in the HO uses the US standard threads verses the Metric but can I pull the mount off the "parts" HO I have and still mount is vertical or can it only be mounted Horizontal? I kinda would like to know if it will mount the same way "Before" I pull it and find out it will only mount Horizontal.
TIA
Old March 23rd, 2005, 13:15
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Re: Renix to HO oil Filter mount
The oil filter adapter, Or what the filter screws to is interchangeable.A standard threaded one can be purchased .It will not be as tall(long) as the metric one.I had the part # and such but it is lost(misplaced as the wife cleans up).
IIRC MADXJ has a write up on this at their site.
Wayne
E-bolt # 530220237 www.madxj.com
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old March 23rd, 2005, 16:40
TUFFXJ's Avatar
Wayne
Thanks...just changeing the center threaded bolts sounds much easyer
Old March 24th, 2005, 14:39
rsalemi rsalemi is offline
You can use the HO unit and turn it upright; similar to the early unit.
Old March 24th, 2005, 15:00
Citat3962's Avatar
Citat3962 Citat3962 is offline
This is good news I wanted to do that and switch to a bigger filter... but I hated the idea of putting the filter horizontal... Cheers!
Oil filter location change? asatxj OEM Tech Discussion 20 March 9th, 2005 13:12
Oil comparison? brtb OEM Tech Discussion 12 March 23rd, 2004 00:43
Installing O-rings in Oil filter L-adapter d10shun OEM Tech Discussion 9 December 20th, 2003 10:51
oil filter elbow bent skog OEM Tech Discussion 7 July 11th, 2003 07:25
OIL in the distubuter?!?!?!?!?!? Stoney Sierra Chapter 5 March 4th, 2003 05:24
