Old December 26th, 2003, 15:32
Lunatic728's Avatar
Lunatic728 Lunatic728 is offline
replacing O rings in the oil filter neck
Well it is going to get into the 40's and 50's over the weekend and it is time to replace the O rings in the oil filter neck. This is on a '90 4.0L.
How do I replace them any thing special they leave out of the FSM?
It there anything I should watch out for?
Anything else I should do when I am changing the oil and the O rings?
Thanks in adavance
Old December 26th, 2003, 16:38
pancake's Avatar
pancake pancake is offline
Re: replacing O rings in the oil filter neck
bolt can sieze...needs a breaker bar of sorts. you prolly don't need the torx bolt, so that's good. lube the new o-rings with fresh oil before putting everything back together. torque the bolt down good, and apply anti-sieze first.
Old December 26th, 2003, 16:42
GI-John's Avatar
GI-John GI-John is offline
It's a pretty straightforward fix.... the only thing I've heard causing problems is the Torx. (some years use regular hex head, some use Torx)
Clean the bejeesus out of the elbow before replacing and lube the rings
Might as well do an oil change while you're at it.
Old December 26th, 2003, 16:59
lunghd's Avatar
lunghd lunghd is offline
My 90 has the standard hex head bolt in the center, not the Torx so ya should get lucky there. Nothin' to it. Just do your regular oil change while yer at it, count on some oil runnin' down below when ya pull it off. New o-rings will be a bit snug just lube em up w/ a little grease & don't crimp/tear em.
No sweat! Even I can do it!
