Old February 9th, 2011, 09:47
EFR98XJ EFR98XJ is offline
P1698 related?
Ok I know this has been beat to death but I have one simple(?) question. I have a '98 with a cluster going nuts and the 1698 code. Been happening for 2 years and only in the winter. Anyway, replaced the gauge harness per TSB and checked all grounds. Still not fixed. Checked neg CCD bus wire from PCM to TCU. Got 4ohms. Checked the pos side and got 1.7ohms. Its obvious that I have an open on that line. My Q is--- Does that open wire affect the cluster? Thanks
Old February 9th, 2011, 18:27
Re: P1698 related?
I'll find out tonight. I'm going to trace the pos bus line (V/BK) from the PCM to the cluster and the TCM. I did something stupid at work and ran a new wire from the PCM to TCM. Got rid of the 1698 but now wiped out communication to the cluster. ALL DATA at work sucks. Does not have any diagrams on the bus.
Error codes P1698 and P1687 BDHershey OEM Tech Discussion 14 September 27th, 2021 19:14
Code P1698.....Please Help! ColoradoRaptor OEM Tech Discussion 6 September 28th, 2008 11:31
Code P1698 ColoradoRaptor Colorado Chapter 17 September 27th, 2008 15:33
Trouble code P1698 89cherokeexj OEM Tech Discussion 4 August 20th, 2008 19:05
Code P1698 any help? Roxtar OEM Tech Discussion 5 September 12th, 2004 21:13
