Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > JeepSpeed, Prerunner and Competition Tech Forum
JeepSpeed, Prerunner and Competition Tech Forum For Discussion of Modications related to Prerunning, JeepSpeed, KOH, Rock Racing, and any other speed based competitions
Old October 22nd, 2010, 01:10
XJRunner's Avatar
XJRunner XJRunner is offline
pics of cages through the stock dash
im about to cage my jeep keepin the stock dash. does anyone have pictures of how they did it? I've searched but cant find any
Old October 22nd, 2010, 13:06
I Beamed Jeep I Beamed Jeep is offline
Re: pics of cages through the stock dash
Well I can get you some from the engine side I had my dash in when I put them in. Clean shot all the way threw. I remember on the driver side it went threw the ac/heater vent area. I hole sawed threw the dash right into the valance then cut a square hole in the engine compartment then replated it back in once the tube was fitted. Funny thing was I was at a show and I asked a jeep speed guy about it he showed me where he went threw but told me it was dumb and not needed and if he were to do it again he wouldn't go threw the fire wall again I had the holes in that night =-)
Old October 22nd, 2010, 15:19
tbburg's Avatar
tbburg tbburg is offline
Check out Larrythedog's build thread. cage pics start on p-10
http://www.naxja.org/forum/showthrea...020245&page=10
The way he has his a-pillar bars are mounted is about what you have to settle for. You can then clearance the dash to fit around the holes His horizontal brace is mounted at dash level. You can either run it a couple inches higher and fit the dash under the bar, or run it a couple inches lower, and hack the plumbing behind the dash to fit around it.
The advantage to running it below the dash is it makes it much easier/stronger to tie into the front structure. Above the dash, you don't have to re-route all the wiring/ducting.
Zoomy97acr has the brace above the dash on his race truck(MJ) and it works really well, but it would be hard to run front bracing down from there. I don't have any good pics of the front cage, but Bajacurt got a pretty good shot showing the brace and down bars through the windshield:
full size photo:
http://www.flickr.com/photos/bajacur...7613501821995/
He does have a full stock dash under the bar, and it can be removed/installed.
Old October 26th, 2010, 22:54
Here is the pic from the engine side driver side it's just a stub now awaiting my new engine cage.
Old October 27th, 2010, 10:35
XJRunner's Avatar
looks like my Jeep is getting caged before november 13th so if anyone has pics I'd really like to see them
Rate This Thread:
No dash instruments or radio after pulling dash Powellae OEM Tech Discussion 2 April 16th, 2007 08:12
Anyone have pics of stock XJ's with really aggressive stock sized tires? nosajwp OEM Tech Discussion 13 December 24th, 2004 21:33
XJ Cages paul_xj04 Modified Tech Discussion 6 October 19th, 2004 19:43
Pics of my stock xj my first run out new96XJheeper Colorado Chapter 3 October 10th, 2004 20:51
exo-cages kegcrawler Modified Tech Discussion 52 August 19th, 2003 20:33
