Old February 19th, 2008, 13:51
TALLRAM's Avatar
TALLRAM TALLRAM is offline
AW4 NO REVERSE OR NUETRAL
Newbe to this forum - 3rd XJ. My current 1993 4.0 AW4/NP231 loads up the engine in park - will not rev over 2000rpm, has no reverse though you can tell it is loading up, has no neutral and will drive forward. All forward gears and shifting are fine including 1st-(2) which is shared with reverse. No bucking slipping all good in forward high reving tire fry ing. Blockage in the valve body? I have changed the fluid & filter (Dex 3) as per dip stick & drain plug. Since the motor was loading up while idling I pulled the fuse on the tcc lock up - no change. I probably have more than one problem and am curious if a mechanical failure in the torque convertor would cause all this. The TPS and NSS are good, I have yet to ohm the Solinoids but have seen nothing about there function that would not allow reverse. HELP
Old February 19th, 2008, 13:54
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Re: AW4 NO REVERSE OR NUETRAL
So you pulled the fuse in the PDC for the TCU?
If you did, then have you adjusted the shift linkage?
Old February 19th, 2008, 14:06
TALLRAM's Avatar
I pulled the 10amp auto trans fuse from the box on the passenger fire wall. The first thing I did was put it up on blocks and eliminate the linkage question by pulling the cable and went thru the selector manually with while running with someone braking for me. When in reverse the trans output shaft would not turn. It is possible I have not taken the power from the locking torque convertor by removing the fuse. How do I open that circuit? Would the torque convertor being locked up all the time stop it from reversing?
Old February 19th, 2008, 15:02
TALLRAM's Avatar
Will the throttle position sensor cable being out of adjustment affect the line pressure enough to keep me from having reverse? If I do not have neutral doesnt that point back to the valve body? Would a blockage in the valve body cause a loaded condition while idling in park? If the torque convertor has a natural stall speed and the engine is idling normally then why would the transmission cause the motor to load up in park unless the torque convertor is faulty?
Any pointers will be appreciated. I have searched the forum (OEM TECH) and found a multitude of AW4 problems but not this one.
Old February 19th, 2008, 16:49
hidesintrees's Avatar
hidesintrees hidesintrees is offline
check out your nss (neutral safety switch) on the rear driver side of your tranny. clean it put diaelectric grease in it and see if that does something? or test it?
Old February 19th, 2008, 18:32
yozsef yozsef is offline
On a Time Out
thats not gonna affect anything.
NO REVERSE (D RANGES
OK)
1. Gearshift Linkage/Cable
Mis-adjusted/Damaged.
1. Repair or replace linkage parts as
needed.
2. Park Sprag Sticking. 2. Replace overdrive annulus gear.
3. Rear Band Mis-adjusted/Worn. 3. Adjust band; replace.
4. Valve Body Malfunction. 4. Remove and service valve body. Replace
valve body if any valves or valve bores are
worn or damaged.
5. Rear Servo Malfunction. 5. Remove and disassemble transmission.
Replace worn/damaged servo parts as
necessary.
6. Direct Clutch in Overdrive Worn. 6. Disassemble overdrive. Replace worn or
damaged parts.
7. Front Clutch Burnt. 7. Remove and disassemble transmission.
Replace worn, damaged clutch parts as
required.
CREEPS IN NEUTRAL
1. Gearshift Linkage Mis-adjusted. 1. Adjust linkage.
2. Rear Clutch Dragging/Warped. 2. Disassemble and repair.
3. Valve Body Malfunction. 3. Perform hydraulic pressure test to
determine cause and repair as required.
Old February 19th, 2008, 19:33
TALLRAM's Avatar
I appreciate the help, since I have addressed the external I quess I will pull the valve body and inspect for trash/blockage or wear. I am still suspect of the torque convertor but all the failures I have seen on them lean to slipping not siezing. The AW4 as I understand it has no bands to adjust unlike the 3-spd. I am hoping for a simple cure meaning low dollar and would imagine someone has been thru this before. Thanks
Old February 19th, 2008, 20:41
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
A simple and cheap cure would be a swap in of another AW4
Old February 20th, 2008, 07:22
TALLRAM's Avatar
NOT what I consider simple or cheap.
Old April 14th, 2008, 18:12
mahanja mahanja is offline
The swap isn't too bad. Cheap is relative. Check around for a good salvage.
Old April 15th, 2008, 09:57
poorboy_616's Avatar
poorboy_616 poorboy_616 is offline
According to the paper work I recieved when I bought my 87 XJ, the PO bought a used trans from a wrecking yard for $150 US.
They are cheap to find, but you have look hard and in the right places...
Old April 15th, 2008, 12:29
Shorty Shorty is offline
Gone but not forgotten...
seized or not, the TC turns the same direction in all gears, so I'd have difficulty seeing it stop your reverse gear but function "tire fryingly" good in forward.
I'm leaning toward valve body plugged up/ gummed up
Old April 15th, 2008, 13:19
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Sounds like a linkage problem to me!!!!! Especially with the forward motion in neutral.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old April 15th, 2008, 18:22
broqenjeep broqenjeep is offline
CLEAN OUT THE NEUTRAL SAFETY SWITCH
Old April 15th, 2008, 19:26
a good idea...... but it doesn't have ANYTHING to do with his problem.
231 true nuetral swap 67TEMP Modified Tech Discussion 5 February 4th, 2008 17:23
WTB: NUETRAL SAFETY SWITCH FOR 96 AUTO jack96xj SoCal For Sale 5 June 3rd, 2007 16:36
tps and reverse john OEM Tech Discussion 6 May 22nd, 2005 19:19
nuetral saftey switch won't go back on jpxj94 OEM Tech Discussion 1 July 31st, 2004 15:23
