I just did mine on my 88 with a 231. Not hard at all, just make sure you get the right seal. The terminology is a transfer case ouput shaft seal, my reccomendation would be Napa since autozone gave me a bad seal. remove the driveshaft, by pulling the rear U-Joint straps (replace these too), make sure you mark it so it goes back in the same orientation. Push the shaft forward, then out (block front wheels, transmission in nuetral). You will only lose a few drops of ATF, a pan is a good idea to be safe. Carefully pry the old seal out, probably it will tear all apart. Put a small amount of silicone sealant aroung the lip of the new seal, and tap it in carefully. If you have a large socket to fit over it tap it in, great but you can still make it work. Installation is reverse of dissasembly. If you are thinking of replacing the U-joints, now is the time. Let me know if I can be of further help
