Old March 7th, 2018, 18:01
Crist Clapper Crist Clapper is offline
Re: Door-panel(s) Installed
Originally Posted by Jeep Driver View Post
Good.
You have the only thread I look for on this site.
Thanks for all the great posts and pics.
So kind of you.... Nice to hear.
Old March 7th, 2018, 23:45
Ralph77 Ralph77 is online now
Originally Posted by Crist Clapper View Post
I want those. They look like they might work on an '00. Did they come on your Jeep or did you buy them? If so where and do you have any part numbers?
Old March 8th, 2018, 08:24
Re: BUILD: My 1987 "Wagoneer" XJ Limited
Parts diagram:
Try these folks:
FRONT
5500 7010 - Larchmont Chrysler @ 914-636-3030
5500 7011 - Larchmont Chrysler @ 914-636-3030
REAR
5500 7014 - Vintage Parts @ 877-846-8243
5500 7015 - Vintage Parts @ 877-846-8243
Old March 8th, 2018, 11:32
Parts diagram:
Try these folks:
FRONT
REAR
Thank you.
Old March 20th, 2018, 19:00
Door-panels: Done!
A bit of a repeat... Some finishing touches. Door-handles/chrome-plates on front-panels. Added speakers in the rear-panels.
Old March 20th, 2018, 19:58
BALTANAKT BALTANAKT is offline
Speakers in the rear. Wow!
Did you do any work on the lock toggle switches to make them black again?
Old March 21st, 2018, 06:26
I was pleasantly surprised there was enough room for the speakers. Although I had to get shallow-baffles, and still trim them. Also, I had to cut a piece of sheet-metal to form a hole/cut-out for all four screws to catch.
All the black lock-toggle-switches are original... The only one that needed replaced because it was damaged... Was the front-passenger's-door.
Old March 21st, 2018, 06:40
Seat-Covers
The Seats/Seat-covers are back from the Upholsterer. A reminder the skins were New-Old-Stock stored in a climate-controlled warehouse for the last 30-years. They were quite the subject of chat at the Upholstery-shop!
Old April 26th, 2018, 06:22
Chasing an intermittent problem...
... is a pain! Intermittently, the door-lock would not operate. Traced all the wires and checked all the connectors... No fix. Finally, found one pin on the connector to the door-lock relay was slightly pulled-out... Fixed!
So then... I decided I wanted fade-on/fade-off courtesy-lamps. Here's what I installed:
(4-seconds fade-on / After doors are closed, a 6-second hold-on, then a 4-second fade-off)
Here's how it is connected:
Old April 27th, 2018, 18:42
Door-panel Courtesy-lamps
Just had to do it...
The lens:
The sockets:
The bulbs:
These are useful little things... Connect in-line to control lamp/light brightness:
Another useful item... Unlike a traditional bit, this bit does not pull carpet. Then, drill a hole in the door-panel metal-frame to accommodate the socket:
XJ: 1987 Wagoneer Limited Or? Windshield trim? Crist Clapper Wanted: Private Party Only 5 November 13th, 2012 16:41
1987 Wagoneer XJ Limited - Trim color? Crist Clapper OEM Tech Discussion 5 July 15th, 2012 16:11
Parting out: 1987 Wagoneer Limited YELLAHEEP For Sale: Private Party Only. XJ ITEMS ONLY 8 June 25th, 2007 22:55
Parting out 1990 XJ "Wagoneer" Limited XJ&CHZ4ME For Sale: Private Party Only. XJ ITEMS ONLY 14 December 16th, 2006 22:19
1987 XJ Wagoneer 6.5" Lift on 35`s + Extras Fairmonco For Sale: Private Party Only. XJ ITEMS ONLY 12 September 15th, 2006 15:37
