notamos
- Fort Collins, CO
Hey all. I figure it's worth asking the crew for ideas before I start ripping things apart.
99 XJ, 4.0 (20k on rebuild), 231 (6 pinion planetary, jb sye, wide chain), d30 (4.56 & trutrac), 8.25 (4.56 & trutrac), aw4, 20k on timken wheel bearings, 20k on axles, 10k on CV driveshafts, 10k on chromos/ujoints front/rear
-Whining or constant higher pitch noise comes from front end when driving.
-Starts at 30mph and gets louder with speed
-Only happens when cold outside & XJ first starts driving. After 5 or 10 mins, stops.
-At 30ish mph, starts like a switch
-Shifting in/out of 4wd has no affect
-Shifting into different gears/neutral has no affect
-Reving engine doesn't change it
-Speed related, definitely rotational
Ideas? I plan to check fluids (axle/trans/tcase), grease ujoints and driveshaft slip joint up front, then open front diff cover. In my mind, sounds like it has to be axle or driveshaft related.
-NA
-NA
