Are my "Up Country" rear leaf springs sagging?
tokarev
Arizona
Hey everyone,
I've got a 2001 XJ Sport with factory "Up Country" suspension.
It seems like my rear end is sagging a little. Can someone please take a look at this picture and tell me if that's a normal amount of arch (or lack, thereof) for a rear up country leaf spring?
Thanks for your help.
Looks to me like your main leaf is shot. The bend before the shackle tells me that because i have the same problem. I put an old set of 3 in aals in and now i have a gap between the main leaf and the aal.
you have an extended shackle dont you?
- Nope. Everything is totally stock except that I recently trimmed the fenders and put on 31" tires.
if not, stock upcountry would be 18 inches center of wheel to bottom of flare
- I wish I could measure it, but like I said, I recently trimmed the fenders. (I installed BW flat fender flares, actually. They require trimming.)
Those springs are shot!
The fact is that unless you have a tremendous amount of weight in the back half of your Jeep, the rear leaf springs should have a u-shape (yours seem flat). It's this shape that creates the downward force to provide "spring."
