open your factory service manul to the dashboard/body section.....complete instructions.
Not gots that huh... :laugh3:
OK
Step 1, grasp the center bezel at the bottom of both sides of the center console and pull. then pull the top out. Start following the screws in counter clockwise direction. Once the trim is off you will be left with 6 or 8 screws holding the gauge cluster in. Remove them. whoops, forgot step 0, disconnect the battery, don't want any chance of the airbag punching you in the kisser...
Take the bulbs out, two sizes and I dont have my old cluster handy right now. Auto parts stores, a good one, should have them.. clean the connectors before putting the cluster back in, it should slide in nice and easy, try it a couple of times and don't bend any of the gizillion tabs in those delf docking.
