As the title says I am trying to figure what all is needed to swap a NP-231 transfer case into a 2000 Cherokee with an automatic and NP-231?
The 91 np-231 is from a 4.0l with ax-15 trans.
The 2000 is an automatic with np-231.
I have searched and found that some have said the spline count is different between the two. I have also found that some are saying that all the t-cases with an ax-15 behind them have a 23 spline output. I would assume that the 2000 with auto would have a 23 spline output as well?
My good friend has the 2000 with a bad t-case and I have the 91 np-231 sitting around and was going to let him use that. I just want to know if he has to swap parts over. I know that the tailshafts are different, could we just swap the 2000 tailshaft assembly into the 91 t-case? Any help or info would be greatly appreciated, we are planning on doing the switch-a-roo this weekend.
