Old October 24th, 2006, 20:17
shelbyluvv's Avatar
shelbyluvv shelbyluvv is offline
Check engine light and rough idle!
I was installing a standard connector on my U-Haul flat 4 connector tonight. I cut the old connector off and was probing the wires to make sure I got everything wired up right. I must have grounded out the wires because I blew the parking light fuse. I replaced the fuse and finished putting the new connector on. I went to start the Jeep and noticed the check engine light was on once it fired up. I shut it off and pulled every fuse from under the hood and fuse box and checked them. They are all good. I then disconnected the battery for 15 minutes hoping to reset the computer. Soon as it light up the light came on again. I let it idle for about five minutes and it started missing and sputtering. If I rev up the engine it runs normal but will miss at idle. If I restart the engine it runs fine for five minutes or so and starts acting up again. Any clue as to what sensor got grounded out by my trailer wiring?
This is on a 2000 XJ auto.
Old October 24th, 2006, 21:16
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cool Re: Check engine light and rough idle!
You probably grounded the backup light through the NSS which will set off a CEL (just a thought). Pull a code to go further on this one.
Old October 25th, 2006, 18:42
shelbyluvv's Avatar
Nope, I must have grounded out all 4 o2 sensors. I replaced them with junk yard jewels and life is good. It runs perfect now.
How to check readings from check engine light Brad Klammer OEM Tech Discussion 2 October 11th, 2006 20:55
Bouncing idle,high rpm on cold start and now check engine light? Rem870XJ OEM Tech Discussion 8 May 10th, 2006 00:09
Rough idle and dieing once engine is warm NitroDuck OEM Tech Discussion 11 September 13th, 2005 16:26
Check engine codes with no engine light rusty1007 OEM Tech Discussion 2 December 18th, 2004 14:19
check engine light on and running rough jamnxj OEM Tech Discussion 8 August 18th, 2003 15:26
