Fuel pump compatibility for fuel cell
94xjsport94
Carrollton, GA
I have an opportunity to buy a fuel cell from a guy in my club (12 gallon RCI, don't have a model #). I've seen rings and things that will allow you to use a stock pump in the cell, but they are all for late models. I have a 98 tank and everything attached to it in my garage from an old XJ. Can I use that pump and all to my 94's harness and fuel system? Don't know what fuel changes there are between the models and google hasn't helped with much.
If so, is it worth the $116 ring from Gen right or should I just cut a hole in the floor and make a box for my stock steel tank?
