CJ's98XJ
- Where the heck is Moyock, NC?
About a year ago I installed an RE lift onto My 98 XJ. Couldn't be happier with it. Worth the extra bucks. Abour 6 months ago i began to notice a loud click when the front left suspension would compress while still connected to the sway bar. Like it does every time I pull into and out of my driveway. Click. I couldn't feel anything and it didn't effect performance any. I was unable to locate it. Now that it has been a while, Click, the big scrape mark on the side of the trac bar mount bracket kinda gives it away. When the suspension compresses and the sway bar is forced up, the bracket that bolts the disconnect to the sway bar hits and then rubs against the side of the trac bar mount bracket. It appears to be cosmetic, but I want to be sure that there isn't a bigger underlying problem. I haven't been in any wrecks or hit the front end hard. What is the best fix? I plan on just grinding down the edge of the disconnect bracket a little. Click. It's driving me nuts. Click.
