Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter
SoCal Chapter The SoCal Chapter covers Southern California and Arizona. Please post local topics here.
Old May 28th, 2019, 13:48
peterjford peterjford is offline
Need an exhaust shop
I need a SoCal exhaust shop that does good work and is trustworthy. I need a down pipe with the 1999 grapefruit sized pre-cat grafted into my current exhaust and done so that it does not put stress on the exhaust manifold (so it doesn't crack again) and I need someone that can find and fix exhaust leaks. Hopefully this can be done for < $500, but I'll pay what it takes to get this smogged.
Peter J. Ford
Purple Is The New Chrome
KK6QQV
Old May 28th, 2019, 14:35
Anak's Avatar
Anak Anak is offline
Stranger
Re: Need an exhaust shop
Probably too far to be practical, but Ed Hanson's Muffler in Spring Valley does good work.
Old May 28th, 2019, 14:38
That's what I get for doing this on my phone... how do I move this out of AAT and into the main SoCal chapter forum?
Peter J. Ford
KK6QQV
Old May 28th, 2019, 14:57
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
You ask one of the mods/admins to make it so?
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old May 28th, 2019, 21:10
David_Bricker's Avatar
David_Bricker David_Bricker is offline
PSR Fire Marshall
Location: Upstate NY-live; Death Valley-play; Hawaii-working on it
A ways a way from you, but excellent work. He's redone the exhaust system on Gomer twice, as we've changed things, including looking up and installing a smaller diameter CARB compliant cat to fit the space I had. Surprisingly reasonable, though no cheap.
Mike's Muffler
12222 Garvey Ave, El Monte, CA 91732
(626) 443-5139
https://www.mikesmufflerinc.com/ttp://
David Bricker / SYR
Gomer - '95 XJ, 2 dr. 4.6L Russ Pottenger Stroker; Novak TJ AX-15; Black Box 2.72:1 + 241OR 4:1; RockJock 60 Front, hydro assist, Hi-steer; D60 trussed and shaved rear; 4.56 ARB Front and Rear; Black Magic discs, Bilstein 7100s front and rear; 35s; PRP seats; Warn PowerPlant winch, hybrid cage. Annd, the Faux Dorkle is gone.
National Treasurer 2013-2021
Not a member? Become one today, and help support YOUR club.
Old May 29th, 2019, 06:21
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Still not close by:
Rogers exhaust shop on Foothill in Fontana.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
SoCal Chapter Past President
Rate This Thread:
Looking for an exhaust shop quinnt North Atlantic Chapter 6 August 4th, 2010 04:51
exhaust shop userbmx1315 South East Chapter 2 April 27th, 2009 21:25
looking for an exhaust shop in san diego homebrew SoCal Chapter 9 November 29th, 2007 01:46
Exhaust shop in OC? Kejtar SoCal Chapter 16 August 13th, 2007 04:00
Exhaust shop in SD OCMI_Teddy SoCal Chapter 11 April 4th, 2007 22:40
