- Birmingham, AL
Shop should have known.
Son's 1997, 5spd, 4.0XJ, 8.25 rear. Bought gear set a couple years ago (good kit would have included notched pinion cross pin). Finally stripped and pulled the rear end and took to a shop for gear install last week. Got axle mounted to springs yesterday and went to pull cross pin to install axle shafts. No go. Guy at shop should have known we needed notched cross pin shaft. Or he should have ground the tooth so the pin comes out.
From what I can see very little grinding on one tooth would be needed.
Do I:
Grind in place under Jeep carefully sealing up case so no shaving get in? If I grind, which side, in other words, will cross pin come out either side? I didn't pay attention when I pulled it and seem to remember on my GMC it only comes out one way.
Pull the carrier? Remove ring and grind? I've pulled a Dana 30 and put it back in but believe you have to be more careful with the 8.25.
Pull the axle and take it back to the shop for notched pin?
Would have liked to get done this weekend, but will not rush if there is right way to go.
Thanks for any advice.
Edit: pictures or links to pictures one each side of shaft, one side I'd have to grind one tooth, the other two, but less.
Do I:
