Old August 4th, 2007, 16:21
redneck redneck is offline
Axle leaking oil out passenger side axle tube
OK, here is my problem. I needed to replace my passenger side u-joint on the front so I pulled it all apart and put a new u-joint in. I slid the axle shaft back into the axle tube and put it all together then took it for a test ride. When I made it back into the driveway all I could smell was gear oil (not a very pleasant smell). Itís coming out of the axle tube. Is there a seal that I missed? I took it all apart again and put it back but still had the same problem when I got back from a short drive around the block. The only thing on the outside that seems to keep oil in and crap out of the axle is a piece of plastic that separates into two pieces. I donít get it. I need to go out of town tomorrow but I cant when I have gear oil spewing all over. This was my first time ever pulling an axle apart so I dont know whats normal but this seems like a problem.
Thanks for any and all help,
Aaron
Old August 4th, 2007, 16:31
Hellbent's Avatar
Hellbent Hellbent is offline
Re: Axle leaking oil out passenger side axle tube
there is a seal back in the housing at the pumpkin that can be damaged if you're not careful when removing/installing the axle. sounds like it got banged up or torn.
Old August 4th, 2007, 17:04
blackdoutxj's Avatar
blackdoutxj blackdoutxj is offline
x2
beat me to it, you have to be gentle when putting those back it...
Leaking Axle tube Jeepdogrob Modified Tech Discussion 4 October 23rd, 2005 17:07
offset front axle(passenger side) XJhabitat Modified Tech Discussion 4 September 10th, 2005 21:57
axle is to far to the PASSENGER side!!! saltilloxj Modified Tech Discussion 14 April 27th, 2005 22:59
NEED passenger side axle shaft from dana 30 jeepinxj05 Wanted: Private Party Only 3 February 22nd, 2005 17:24
8.8 passenger side axle shaft tiblerbrit Wanted: Private Party Only 0 August 19th, 2004 09:01
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
