Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor Advertisements
Old May 15th, 2019, 12:36
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Exclamation New Product! Titanium 4.0L Manifold Stud Kit!
Another BWE exclusive!
Replace your OEM manifold bolts and cone washers with our high strength 6Al Titanium stud kit! We include 11 machined Titanium studs that are much stronger than the factory bolts that also provide much greater corrosion resistance. We also include new gold zinc plated 1144 high strength steel cone washers that are also much stronger than the OEM stamped steel washers. Then we top off the kit with high-strength and reusable Mil Spec lock nuts that will not loosen over time.
Benefits of our Ti Stud kit:
- Much stronger than the OEM hardware
- Provides even clamping pressure on the gasket
- Added corrosion resistance
- Easy installation (Studs have 5/32 machined hex)
- Will not loosen over time!*
Kit Includes:
11 - 6Al Titanium Studs
9 - 1144 steel cone washers
2 - Grd8 washers
11 - Mil Spec lock nuts
* You'll need to use some med strength thread-locker when installing the studs in the head.
$115 Shipped!
http://www.boostwerksengineering.com...Kit-_p_39.html
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old May 15th, 2019, 19:52
Anak's Avatar
Anak Anak is offline
Stranger
Re: New Product! Titanium 4.0L Manifold Stud Kit!
Ooh!
Hardware porn.
Talk about a lack of moderation...
I am tempted to order a set now just in hopes that I will have something cool before Cal has it.
Baby it's cold outside.
Old May 16th, 2019, 13:19
lol. You should just to shove it in his face.
Rate This Thread:
busted stud on the manifold Kejtar OEM Tech Discussion 31 June 15th, 2011 10:22
Exhaust manifold stud missing my2monkeys OEM Tech Discussion 1 September 6th, 2009 10:16
Exhaust Manifold Stud Replacement Questions Muad'Dib OEM Tech Discussion 73 July 30th, 2008 23:08
4.0 exhaust manifold stud Grand CJ OEM Tech Discussion 0 August 8th, 2005 03:55
exhaust manifold stud removal 2xtreme OEM Tech Discussion 3 February 21st, 2005 06:21
