Check out these rear leaf springs
Mirage mobile
MO
Hey guys,
I would like your opinion on the arch/flatness of my rear leaf springs. I felt the rear suspension has gotten significantly stiffer over the past 5 years and these images may show why as the leaves are getting pretty flat and increasing the effective spring rate. What do you think?
The following images are with the jeep unloaded and the axle tube set at ride height (images with no tire).
Setup (installed 5 years ago):
OME CS033RB leaf springs
JKS shackles
LII shackle relocation brackets
shackle angle roughly 45 degrees
