Bronco
- Swansboro, CA
Loose Track Bar
The hole in the axle bracket for the track bar on my jeep is starting to get enlarged. It’s kinda one of those the worse it gets the faster it gets worse things. So I figure I got at least two options:
By the way I am running an RE lift with there 1600 Track bar.
- Get some plates welded on to both sides with the appropriate sized hole. They could be kinda thick and that would make it kinda bullet proof. Getting it done would be a pain and I would need a longer bolt. I’m not even sure how one would get the plate on the back side.
- I could just drill the hole out to a bigger size and put in a bigger bolt. Th problem there would be replacing the fancy Nut in a stick thing that letts you get the nut on.
