Old September 14th, 2020, 18:57
jlmxj49 jlmxj49 is offline
Evaporator Core Molded Styrofoam Piece
So after putting it off for several years, I finally pulled the dash on my 2001 Cherokee to replace the bad evaporator core heater core, and old fan motor. The foam that is stuck on the top and ends of the core are good. Actually, I can peel them off and glue them to the new core. The problem is the molded styrofoam piece in the bottom of the box. Where the lead was it ate away the front 1/3 of the bottom. From there back is in decent shape. For those of you who have ran into this, what did you use to replace it?
Old September 14th, 2020, 19:31
RCP Phx RCP Phx is offline
Re: Evaporator Core Molded Styrofoam Piece
Use "non-expanding" spray foam, there are a lot of different types but most will stick to the housing/core (if you think you'll ever do it again) so "wrap" them in something like "Saran" wrap prior.
Old September 14th, 2020, 20:06
Dang! I didn't even think about that. That should work. I'll look for some tomorrow.
Changing evaporator core - thinking of reusing heater core jeepingben OEM Tech Discussion 6 March 29th, 2013 16:28
Evaporator Core problem sorenoneill OEM Tech Discussion 1 April 20th, 2011 18:32
Evaporator core recommendations anthrax323 OEM Tech Discussion 5 January 7th, 2011 08:47
AC evaporator core diagnosis? XJ Eric OEM Tech Discussion 5 April 17th, 2008 05:57
Evaporator core aroberts OEM Tech Discussion 5 June 24th, 2005 07:40
