Old September 9th, 2020, 00:43
xjismydd xjismydd is offline
Bumper Interchangability by Year?
I have a '92. I messed up the bumper. It is the older style with two Torx bolts on the bottom, and two in the front.
I want to go to the JY and not pull off all the bumpers until I find one. So I'm hoping someone knows if newer ones (where there are two Torx bits on top and two on the bottom) are compatible. Any other weird issues I should know about?
Thank you.
Old September 9th, 2020, 03:54
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Bumper Interchangability by Year?
The old and new body style front bumpers do not bolt on interchange. The fender sheet metal and the bumper end caps are different as well.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old September 9th, 2020, 05:10
BIGSLVRXJ BIGSLVRXJ is offline
84-96 interchange
97-01 interchange
You can make a 97-01 bumper work on yours as long as you get the brackets too but you will have to drill new holes for your end caps and the contour won't match perfectly, there will be extra holes in it, etc.
Old September 9th, 2020, 06:39
Tim_MN's Avatar
The fenders will need to be trimmed also.
Old September 9th, 2020, 11:06
Only if he was to use the 97+ end caps right? I was referencing using his original end caps. I didn't think you had to trim if you kept the older end caps.
Old September 9th, 2020, 15:36
Tim_MN's Avatar
Yes, correct.
Old September 15th, 2020, 19:02
50willys's Avatar
50willys 50willys is offline
I still have the stock bumper off of my '96 if you need it.
Bob S.
'96 Cherokee, 4.0L w/Auto Trans & locked D44s
Year End Bumper Sale! WebDog Vendor Advertisements 3 January 5th, 2013 15:01
A 17 year olds garage built rear bumper! Cole93maxxxj Modified Tech Discussion 60 August 22nd, 2011 14:16
OLDER YEAR ARB BUMPER FIT ON A NEWER YEAR CHEROKEE C85D4x4 Modified Tech Discussion 6 September 26th, 2006 17:32
Front bumper -- any year xj-grin Wanted: Private Party Only 1 December 23rd, 2004 21:03
Bumper sticker of the year XJ_ranger Non-Tech / Off Topic 1 September 15th, 2004 18:40
