Old October 6th, 2004, 12:48
shimmy's Avatar
shimmy shimmy is offline
blinker to hazard lights
sometimes when i turn on the left turn signal, both rear tailight signals flash like hazard lights... do i need a new blinker or could it be something else?
brandon
Old October 7th, 2004, 02:26
Chancer's Avatar
Chancer Chancer is offline
Re: blinker to hazard lights
Sounds like an electrical/ earthing problem to me: the hazard & indicator relays are separate units, so you must be getting a crossed wire or something. Good luck.
Old October 7th, 2004, 02:43
XJJPR XJJPR is offline
Maybe low blinker fluid?????
hinkley
PS check flasher unit, might be bad and shorting out inside.
Old October 8th, 2004, 11:54
shimmy's Avatar
crossed wires would suck arse! i'll replace the blinker unit and see what happens...
thanks
brandon
Old October 8th, 2004, 19:34
casm's Avatar
casm casm is offline
Some cars use a common relay for the indicators and hazard lights, only pulsing one side or the other for indicators but both sides for hazards. I don't know if the XJ uses this setup or not, but in some cases it can be a sticking relay. If this is the case, you might want to check if the flasher relay is good or not.
Old November 1st, 2004, 07:31
SteveJ7 SteveJ7 is offline
Hey shimmy, did replacing the blinker unit solve your problem?? I have the same problem on my '98 XJ. Any info about what you did to correct this would be great! Thanks!
Old November 2nd, 2004, 18:37
JoBo JoBo is offline
My 96 XJ has a dual flasher as you discribe.
JoBo
Old November 2nd, 2004, 18:43
Boatwrench's Avatar
Boatwrench Boatwrench is offline
very rare occurence but if the filaments in a bulb are touching making contact current will feedback throught the wire and light the other side. The fronts won't be affected by ther ears because of the stop light switch.
Also if there is a short circuit in the turn signal switch it could effect the stop lights.
Tom
Old January 14th, 2005, 07:28
CRASH's Avatar
CRASH CRASH is offline
Damnit, our 99 is having the same problem, and I saw a 2001 doing it as well.
Anybody ever track this issue down? Please tell me I don't have to go digging through the airbag to get to the turn signal mechanism......
Oh, one thing I did notice: If I just move the turn lever far enough to begin the blink, it doesn't flash the hazards. As soon as it "clicks" into the turn position, the hazards come on.
Weird.
Old February 1st, 2005, 10:46
n3msk n3msk is offline
Angry Re: blinker to hazard lights
I have the same problem with my 97.
Old February 1st, 2005, 13:13
UNCC_99XJ's Avatar
UNCC_99XJ UNCC_99XJ is offline
Twisted Up
My 99 did it about a month ago, 1 block after i pulled off the lot from purchasing it. Turn signal switch was bad, and a new one did the trick.
Old February 2nd, 2005, 07:38
Do you have to remove the steering wheel to change the switch?
Old February 2nd, 2005, 19:01
UNCC_99XJ's Avatar
Twisted Up
Honestly I can't tell you. This was my first freebie fix from carmax. I remember he traced wires first, looking for obvious splices, shorts, and frays, and then found the bad switch. I would imagine so, just to make things alot easier to get to. maybe not the whole wheel, but the plastic square part between it and the dash?
Sorry I can't be of more help, as I didn't do the work my self.
On another note, I saw a 2000 doing the same thing on my way to pick up my jeep yesterday,
Old February 2nd, 2005, 19:47
Boatwrench's Avatar
Yes, the steering wheel needs to be removed to replace the turn signal switch, which means the air bag also and the wires need to be fished down through the column. It a PITA.
Tom
Replacement Backup Lights Wiring Question gpthrlz Modified Tech Discussion 6 September 27th, 2004 06:15
help wiring extra dome/cabin lights.... CaptTrev Modified Tech Discussion 9 February 21st, 2004 19:43
Back Up Lights - Not NSS coach9119 OEM Tech Discussion 4 January 29th, 2004 13:22
Blinker dead pejeeper OEM Tech Discussion 7 January 3rd, 2004 22:00
Rock Lights Cresso Modified Tech Discussion 12 April 15th, 2003 22:39
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
