Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Non-Tech / Off Topic
Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period.
Old August 7th, 2004, 19:51
hackedxj's Avatar
hackedxj hackedxj is offline
NAXJA Member #1090
Need Tig Welder advise !
I've always wanted a tig welder to weld aluminum and have finally decided to get one. I have only had the chance to use a tig a few times and really enjoyed it. Since I have very little experience, I don't know what I need in a tig welder. I went to a welding supply to check out some different models but came away a bit overwelmed by all the different features. I'm not going to be doing industrial welding, but I want a welder that can do some nice welding.Can some of you guys point me to a good model ,maybe some features to get or not to get.Can a good welder be had for around two grand? I just hate to buy one and realize it's not the one I need.With all the rigs I've seen here surely someone has some knowledge to share.Thanks for any advise.
Old August 7th, 2004, 19:58
KY Chris KY Chris is offline
Re: Need Tig Welder advise !
Should be able to get one of these for around 2000. I would imagine this would do pretty much anything you want. AC/DC. autosinc lets you run off 110 to 440 automatically, plus you can stick weld with it, too. It's really easy to set up and it's very portable.
http://www.millerwelds.com/products/tig/dynasty_200/
Old August 7th, 2004, 21:30
Lincoln Lincoln is offline
NAXJA Member #321
If you want to weld aluminum make sure you get one that will handle the thickness's you want and size comes into play too. I'm far from a TIG (or aluminum) expert but I really like the foot pedel while welding aluminum. Aluminum conducts heat so well so what's good when you start is too hot after some bead has been put down.
You could alway's buy one and let me try it for a while. If it's good I'll just keep it.
Old August 9th, 2004, 06:37
4ward's Avatar
4ward 4ward is offline
Have you thought about buying a used welder? My Hobart CT-200 cost $400 It's about 20 yrs. old and it rocks. If you are wanting to do aluminum, you had best be getting a water cooled torch. I've already melted 2 air cooled torches. Aluminum takes a LOT of amps to weld correctly.
Old August 9th, 2004, 07:26
Beezil Beezil is offline
Member #Nay
We use a synchrowave 180.
I have no persnal experience with it, other than to report it is a trouble-free unit, has provided excellent service with occasional production orders in alum and stainless.
Old August 9th, 2004, 08:18
dmillion dmillion is offline
Anyone have any experience with this...
http://www.tigdepot.com/products/p35TD-BBTF.htm
Looks like a cheap way to get into TIG since I already have the AC/DC buzz box.
Old August 9th, 2004, 16:46
NAXJA Member #321
I've looked into those, but if your planning on welding aluminum I wouldn't waste the money. Also, I've alway's used AC Tig on aluminum and was always told to not scratch start. 125 amps wouldn't really do much either. I don't think you could even get 1/8" to burn good.
I believe any AC/DC arc can be setup to do DC TIG (scratch starting). That's where I learned how. It appears the only thing their doing is dropping the current for more control on the real think stuff. Dmillion, go talk to your supply store. You should be able to get a torch setup for around $100 then add a tank and start. You won't get the automatic gas flow control but it's fun to play with.
I've been shopping for a TIG box for a while now. Don't really need one so I haven't shopped that much. I've fought my way through most of mine with the MIG but more power and a spool gun would make life much better.
Old August 9th, 2004, 16:47
NAXJA Member #321
I have to ask for comparision sake. How many times have you touched the filler to the tip?
Old August 10th, 2004, 05:16
4ward's Avatar
Probably a couple million
I was having serious problems with it until I realized that dragging the cup on my workpiece made things pretty smooth. I've been told by several very experienced welders to not let your filler get outside of the gasflow. That was a problem for me for some time.
Old August 10th, 2004, 05:21
XJJPR XJJPR is offline
Mine is trouble free also, but then I've not even hooked mine up yet!
hinkley
Old August 10th, 2004, 06:09
notorious DUG notorious DUG is offline
Dehinetly think about buying used, we got a syncrowave 250 for around 400 bucks at autction, already setup with a liquid cooled torch. Wroks great and double sas the king of all stick welders with the high freq AC start.
Rate This Thread:
Redi Welder ??? GRNT Non-Tech / Off Topic 3 January 19th, 2004 20:04
Wire or stick welder, help me decide. JEONLYEP Modified Tech Discussion 15 December 23rd, 2003 08:53
Junkyard Made TIG Welder! MrShoeBoy Modified Tech Discussion 19 November 5th, 2003 12:54
Advise on used 89 MJ alldz Non-Tech / Off Topic 14 September 17th, 2003 05:13
which TIG welder?? JJ13 Modified Tech Discussion 3 July 25th, 2003 08:09
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
