Old April 26th, 2010, 14:46
Magus2727 Magus2727 is offline
Mounting of Full size CB radio?
I just got a CB radio (Cobra 29, the Blue Tooth one) and am thinking I want it mounted between the sun-visors but wanted to get other peoples input who may have had it located there or have it else where and what the pro's and con's are!..
Thanks!
Old April 26th, 2010, 14:55
ReverendOD ReverendOD is offline
Re: Mounting of Full size CB radio?
Im fighting with the same decision, have a Uniden PC68XL. Im thinking mounting it on the back of the cetner console but not sure.
Old April 26th, 2010, 14:58
matttaylor1976 matttaylor1976 is offline
i have mine up there. Its in the perfect spot in my opinion. Out of the way of passengers, and not as likely to get damaged. The only thing to worry about is the mic swinging around and hitting passengers. make sure the mic mount is nice and tight.
Old April 26th, 2010, 15:18
RenegadeStang's Avatar
RenegadeStang RenegadeStang is offline
I love mine up there. I did a simple fab of an aluminum stock mount to keep it up there. The mic cord doesn't get in the way at all.
Old April 26th, 2010, 15:21
97XJ2's Avatar
97XJ2 97XJ2 is offline
My Uniden PC68LTW is on the back of my center console. Out of the way and not readily visible.
Old April 26th, 2010, 15:38
Got a picture of it mounted?
Old April 26th, 2010, 16:03
97XJ2's Avatar
I'll get one shortly
Old April 26th, 2010, 18:34
Does that get in the way of putting the back seat down?
Old April 26th, 2010, 18:56
Humm I can only imagine will will, would be worth making a flush mount way to quick disconnect it when you need to lay the seat down.
Old April 26th, 2010, 19:20
97XJ2's Avatar
No actually, I can flip the seat bottom forward and still have the seat back fold flat. It's tight but can be done. No problem if you take the seat bottom out, no problems whatsoever. I'll grab a pic of that too.
Old April 26th, 2010, 23:15
CherokeeManatee's Avatar
CherokeeManatee CherokeeManatee is offline
I have mine up between the visors as well - not as cleanly done as the pic above.
I don't have it hardwired (yet) into power so when not plugged into the cig lighter the cord is wrapped around the mirror.
Took out the keyless entry receiver (never did get the buttons to go along with it) and the cobra bracket screws right into existing holes.
Only problem is the mic falls out of the holder - I bend the tab in but the bumps and hills when 4x4ing loosen it up.
Old April 27th, 2010, 07:45
97XJ2's Avatar
Here,
From above.
The side.
Seat down, tight, but no excessive pressure on the radio as I can still get fingers in between the seat and the radio with no problem. And obviously no problem with the seat bottom removed. The diamond plate is on the back of the seat and in the floor in the back, but nothing that differs from stock in folding the seat down.
And if you were to actually look in the vehicle for something, not seen readily passing by. Those are WJ buckets.
Old April 27th, 2010, 07:55
Sideshow's Avatar
Sideshow Sideshow is offline
I have the CB mounted between the visors as well. I think its a great location because the speaker is easy to hear, and the radio is less likely to get wet or dusty. Here's a bad picture of mine:
Old April 27th, 2010, 07:58
ECKSJAY's Avatar
ECKSJAY ECKSJAY is offline
Water is dirty
Not a big fan of overhead mounts (or anything mounted over my head) and anywhere I can't see the radio. I ran a 29LTD Classic on the passenger side of my console by the shifter for years. It didn't get in the way of passengers because the space consumption was negligible and the top of the radio was smooth. I had the base mounted to the side of the console and reinforced with a piece of flat bar. Face up so I could see the radio. Never had a problem with theft. As a matter of fact, all the stereo gear and CDs were stolen several years ago and nobody even touched the radio here. Sorry, I don't have pics.
The current radio is a Cobra 19 something or other...and it's mounted on the right hand side of the console, below the dash on the face of the knee bolster. It's even more out of the way now than the 29, but it's also less than half the size.
Old April 27th, 2010, 08:03
97XJ2's Avatar
Oh yeah I have some rubber grommets in there so there's a little flex in my mount. A piece of flatbar inside the console that I have bolted to so it won't pull through the plastic. Did remove the rear seat ashtray so I could do it that way. I hear the radio just fine too. It gets just as dusty as the rest of the interior does.
My next radio will be a cobra 75stwx for the WJ, figured I wanted something smaller for that vehicle.
Writeup - Overhead Mounting of Uniden ProXL520 CB Radio CaliGold Modified Tech Discussion 10 April 11th, 2010 21:20
How do you fit a full size Jeep in a half size garage? GSequoia SoCal Chapter 13 May 11th, 2008 11:15
[B]CB Radio Ceiling Mounting?[/B] mbiker72 Modified Tech Discussion 12 January 28th, 2008 17:10
Mounting an Amateur Radio kd5dwy OEM Tech Discussion 8 January 30th, 2007 12:17
Dual radio mounting azdesertrhino Modified Tech Discussion 17 January 8th, 2006 13:22
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
