Old August 15th, 2022, 17:44
Xjin85 Xjin85 is offline
What BRAND Tranny fluid and T-case fluid do you use? (AW4/NP231)
So, I have a 2001 XJ, with an AW4 transmission and an NP231 transfer case.
I am going to be changing both my Transmission fluid and T-case fluid this week and will be using Dexron fluid as per the FSM recommendations.
Seems like Dextron III is no longer existent and now there is only Dextron V and VI.
My question is: What BRAND Dexron compatible fluid do you use?
I am personally leaning towards:
Redline D4 which seems to be a good suitable substitute for Mercon III
Royal Purple Max AT
F- I've heard great things about RP but when reading the product's description it seems to be a substitute for every trans fluid...Including ATF+4 which I am avoiding to use.
or Valvoline DEX/MERC ATF Max Life
The most important thing I'm looking for is which will reduce the amount of heat and wear on the tranny all while shifting smoothly.
Can any of you guys give me input on any of these products and how they react with your XJ?
Old August 15th, 2022, 17:48
Re: What BRAND Tranny fluid and T-case fluid do you use? (AW4/NP231)
Also, How much fluid does/will both the Transmission and T-case need?
Old August 15th, 2022, 17:49
RCP Phx RCP Phx is offline
I'm going to say something nobody wants to hear, 22yrs now on my 2000 with Amsoil!
Old August 15th, 2022, 18:48
xcm xcm is offline
I don’t care if nobody wants to hear this, and I know for a fact the OP won’t, but skip the fancy fluid, and spend the $$$ on a fancy trans cooler. As far as the tcase goes, it doesn’t care.
It’s a jeep, not a Ferrari.
Old August 15th, 2022, 18:52
xcm xcm is offline
The tcase has a fill port, fill it til it weeps.
The aw4 has its own procedure for checking fluid, but capacity is dependent on if you have a tow package (and aux cooler, and extra lines). IIRC, you want to check it warm, idling in neutral on a flat surface. Check it, test drive, check it again. Low level can give you a box full of neutrals. Too high and it’ll blow out the extra…
Old August 15th, 2022, 20:31
jeep ride's Avatar
jeep ride jeep ride is offline
I used the Napa brand it's made by Valvoline part # 75 200 in my 98 xj tranny and t case both on the Tcsse make sure you can get the fill plug loose before you drain the fluid.
Old August 15th, 2022, 21:07
Originally Posted by xcm View Post
I donít care if nobody wants to hear this, and I know for a fact the OP wonít, but skip the fancy fluid, and spend the $$$ on a fancy trans cooler. As far as the tcase goes, it doesnít care.
Itís a jeep, not a Ferrari.
Ahhh, the good old "it's a jeep, not a Ferrari" You know what? It is a Jeep..My jeep..not your Jeep. And let me tell you my friend that it most certainly does matter. Especially with a truck about to turn 200k don't the tranny. It's not about fancy fluid...It is about putting quality in my jeep to make it run top. In regards to your transmission cooler statement, who said I don't have one? Let's stick to the narrative buddy, OK?
Old August 15th, 2022, 23:10
maxbraketorque maxbraketorque is offline
I went through the ATF discussions threads after I bought my XJ, and I think the most common answer for a particular brand and variant is the Valvoline Max Life ATF. That's what I'm running in mine now. Seems to be a quality product that works in an autotrans that requires Dec/Merc III. As xcm said, put in a trans cooler. An AW4 in an XJ gets toasty in hot weather, even just driving around town.
The TC also calls for ATF, specifically ATF+4. For my freshly rebuilt TC, I went with Amsoil SS Multi-Vehicle ATF. Its a +4 rated ATF. Valvoline Maxlife in the TC would be fine too and keeps it simple.
Old August 16th, 2022, 04:10
Ralph77 Ralph77 is offline
What jeep ride said.
I retired out of a Napa but the simple fact that on the container it says DexIII/Merc makes me happy.
Also what he said about the fill plug on the transfer case.
Unless your tranny pan is leaking and you want to replace the gasket just pull the drain plug.
About 3.5 quarts will come out.
If you don't feel it looks quite as clean as it should after you do it after driving for a bit do it again.
IIRC about a quart for the transfer case.
Old August 16th, 2022, 05:06
75SV1 75SV1 is offline
I use the NAPA DexII/MERCON. About 3.5 quarts. I do change it every year or so. T/C I'd use the same. Still, I think I used a synthetic in one. I wouldn't disagree with the ATF+4 in the TC though. Still, I like to keep a minimum of oil types around. There are synthetic DexII/MERCON available. I did ask in another thread if people had issues with a synthetic in the AW4. About 4-5 said no. All were handles I recognized. Might go that route, as I plan to put a trans I had rebuilt in my 2000 XJ. Sort of settled on build plans, as to what engines and trans will go with what XJ or the MJ.
Edit: NAPA oils are Valvoline rebottled. I like to change the trans oil, run about 250 to 1000 miles and change again with one I just bought. I do add one bottle of Lube Guard in the red bottle. I also run a trans cooler.
Old August 16th, 2022, 05:25
cruiser54's Avatar
cruiser54 cruiser54 is offline
valvoline Dex/Merc III.
Pick up about 6 quarts total.
Just do a drain and fill on both the trans and transfer case.
Old August 16th, 2022, 06:16
Anak's Avatar
Anak Anak is offline
Stranger
xcm's advice is good advice.
Neither in your transmission nor in your T-case do you have the issues regarding hydrocarbons that you have in the engine. Heat is your biggest issue for your automatic transmission. If you care about your transmission then the addition of a cooler is more important than the difference between one brand of fluid and another.
Old August 16th, 2022, 06:33
cruiser54's Avatar
6 quarts to be safe.
Old August 16th, 2022, 06:36
jeep ride's Avatar
I would like to have a dollar for every case of 75-200 I delivered in 35 years Lol
Old August 16th, 2022, 08:42
crispyluck crispyluck is offline
Dex Merc VI, Valvoline High Mileage
AX-15 & NP231 T-Case Fluid Info Needed MassMopar OEM Tech Discussion 4 November 19th, 2013 10:26
tranny fluid spraying out of tranny dip stick(one time only) stoneyva21 OEM Tech Discussion 8 July 13th, 2009 21:20
Tranny Fluid for T-Case Questions 98XJSport OEM Tech Discussion 9 July 17th, 2006 09:58
ATF Fluid Brand bustednutz OEM Tech Discussion 3 November 9th, 2005 21:58
Transfer Case -- Tranny Fluid ONLY mgreen84 OEM Tech Discussion 2 November 5th, 2005 14:36
